Hi Guys & Girls,
I am selling my set of Super Advan Racing SA3R V.1 wheels which were originally on my JZA80 supra. In good condition and minor gutter rash on 2 wheels (hardly noticeable as evident in photos).
ITEM: 17" Super Advan Racing SA3R V.1 Wheels with near new tyres
ITEM DESCRIPTION:
Front - 17x8 +35 offset fitted with 235/45/ZR17 ACHILLES ATR SPORT with 80% tread left
Rear - 17x9 +38 offset fitted with 235/45/R17 EVENT WL905 with 90% tread left
As mentioned earlier these rims are in good condition with minor gutter rash on 2 wheels. Im selling them cheap as they are no longer needed and are sitting in the garage collecting dust. The stud patterns of skylines & supras are the same which is why they should fit with no dramas. Plenty of tread left as I had replaced the rear tyres prior to removing them from my car.
REASON FOR SALE: Upgraded to 19inch bling blings. No longer needed.
LOCATION: Gold Coast. Prefer local buyer as I'm not familiar with freight rates
PRICE: $500 Firm.
CONTACT: Either PM or email [email protected]
I'll get back to you fairly quickly even though Ill be at work
post-33425-0-06023600-1329103376_thumb.jpg post-33425-0-74298800-1329103469_thumb.jpg post-33425-0-16277900-1329103558_thumb.jpg post-33425-0-49898000-1329103641_thumb.jpg post-33425-0-10734200-1329103719_thumb.jpg post-33425-0-78170100-1329103802_thumb.jpg post-33425-0-39447000-1329103865_thumb.jpg post-33425-0-63710900-1329103938_thumb.jpg post-33425-0-57025100-1329103995_thumb.jpg
https://www.sau.com.au/forums/topic/391559-17-super-advan-racing-wheels/
i want them but im in nsw i can arange freight if u can get them to depot.
wheres the nearest depot in Gold Coast or Brisbane? I might consider it if it doesnt sell by end of next week or possibly earlier.
Starting to get impatient with them as theyre taking up car parking space :unsure:
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
