Nissan (350Z) Import Fairlady Z 2003
Engine
VQ35det 6 Speed
[email protected]/8psi" [email protected]/8psi boost
ORC super single clutch
Full HKS 3037pro turbo kit (screamer pipe)
HKS injectors, 660cc
Tial 50mm BOV
Heltech 350Z Platinum pro plug and play
GReddy Bspec 2 boost controller (7.5/8psi)
Fujitsubo Legalis R exhaust
Walbro 550cc fuel pump
Trust oil cooler with remote filter
Braided clutch line with new slave
Exterior
Full vertex body kit
20x9.5+6 Front, 20x10.5+0 Rear, Work VS-XX rims
Rear LED 350Z lights from the 07' model
Carbon Fibre roof lip
Carbon Fibre Garnish door and mirror pillars
Carbon Fibre Aerial
Carbon Fibre Air Intake Duct
Belloff HID 9000K HID lights
LED parkers
Tinted windows
Suspension
Tanabe GE sustec pro adjustable
SPC rear camber arm
SPC traction rods
SPC toe bolts
Replaced front standard bushers with nylon bushers
Interior
Z floor mats and boot mat
Nismo GT shift gear knob
Z aluminium side steps
Nismo gear H pattern
Stereo
Pioneer 6.5inch TV/DVD/MPZ player
Alpine amplifier
Pioneer 6inch carbon fibre front splits
Pioneer 10inch subwoofer.
will come with rwc and rego
car is in brisbane/gold coast area
also comes with a standard set of wheels
this is also the only (350z) import that is road legal in australia that i no of...
most mods done in the last 6months
crack in front bar will be all fixed before sale
car has 13x xxxk's on it
motor has 72 xxx on it
$37 000ono with rims
$33 000ono with out the work rims
Rossi 0401567736
NO SWAPS
Edited by 12slide
https://www.sau.com.au/forums/topic/391580-nissan-z33-350z/
OP... Y U NO sell this a month ago?! Is exactly what I was looking for but eventually gave up lol. Goodluck selling this monster :)
It was for sale a month ago just not on this site...but cheers..
https://www.sau.com.au/forums/topic/391580-nissan-z33-350z/#findComment-6239939
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
