"steam Pipe" Single Turbo Manifolds On Fleabay....anyone Know Anythging About This Supplier And Their Products?
  • Replies 384
Kam, any chance you would be considering a low mount manifold?
There is a distinct lack of affordable (same price range as your high mounts), available (HKS items are rather hard to find), low mount (put the turbo flange in same position as stock manifold does) exhaust manifolds..
Kam - Do you make a low mount option without a wastegate mount?
For RB25, using internal wastegate Garret turbo.
I would also like to know if you could make a manifold with an alternate flange plate?
IE I would like an SR manifold in highmount design but with an EVO flange plate.
Would love to know and asap :)
What power have pepole made with these ?? Anyonr made dececent power ?? Hoping to push 300 plus with 44mm gate
Guys, If anyones after a genuine HKS RB26 Low Mount T4 manifold and matching 1bar wastegate, I have a brand new, unsued one for sale...PM me??
well im doin 355kw with a shit chinese manifold... so id assume ud do the same power if not more on one of these
Hi guys,
Sorry we have been flat out,
As for the low mount manifold i don't think we will be making them as the demand is not very high and last time we did it sat with us for months.
I will be making some new manifolds in the next few weeks,
1) No WG port option (so you can run direct off the back of the turbo or if you have a internal gate )
2) the Collectors will be smoother and will have a better flow we already have some ideas,
3) Exhaust flange will be machined after and checked with a straight ruler for no gaps,
4) 2 options 44mm / 50mm waste gate option ( would any one need a 60mm option ? let me know prior)
Any more info or adjustments let me know !
Regards
Kam
38mm options already in stock,
Who else would prefer 40mm over 44? let us know what you guys want so i know what to make for you :)
Thanks
just want to point out that this weld while it looks nice and pretty is NOT a strong weld. theres a large amount of undercut on the edges. needs more filler wire as it loks like its just been fusioned together
I regards to kams manifold seeing my mate bought one and is currently using it has been long before this thread started i can say that his.setup on a stock rb25 with gtx3076 works fine straight of the gate holds 14psi no problems no boost creep he is running a 50mm tial gate currently and makes 260 rwkw safe as its a drift car and he is very heavy footed.it did make 295kw at 17psi but was taken back to 14psi till he got more used to the cars setup
Hi guys,
Regards
Kam
Pity :/
Kam, i want one with a 44mm V-Band Wastegate outlet, with 44mm ID wastegate pipeing too and your new improved ported merged collector, T4 Flange. Please drop me a PM on here with the price and leadtime bud?? Cash waiting plus if the manifold is good Ill do a full writeup for you on the UK GTR Forums!!! Cheers, Andy
Just a point too........anyone running a RB26 or bigger with T4 framed Turbo should have a 44mm wastegate as minimum in my experiance.....im guessing thats why "other" manifold manufactures build with 50mm dia wastegate tubes and flanges??
I've got cash to purchase one so ounce uve made the new manifold I will purchase one with 44mm gate
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
