"steam Pipe" Single Turbo Manifolds On Fleabay....anyone Know Anythging About This Supplier And Their Products?
Some one was saying that the welds ( wernt pretty ) because we had used a tig and not a mig on the last Wg port we did, well from now on we will use a mig as much as possible. here is a few of the ones we have recently finished and because some one had stated they didn't like how the mig welds looked ( which does not actually effect the performance of the manifold ) we took your ideas on board and made the welds look pretty :) The large one is a 50mm port with a 50mm gate, the smaller one with the gate is a 38mm port and a v band gate, and the last one is a 44mm port with no flange.
  • Replies 384
cant wait to order myself one of these! get rid of my chinese leaking POS. didn't know welds were such a big deal specially when u dnt even see half of the manifold anyway or its covered in heat wrap... each 2 there own.
hi,
can you do a low mount option for RB25 with 44mm ext gate opening??
Giday mate, i won't be making low mount setups at this stage but maybe in the near future.
Kam
Mate when I said mig welds were not appealing I said that from one welder to another and from a customers point of view aswell it's not a personnel attack moreso advice for criticism to come .
I personnly think for the price ur manifolds are it is a steal I would go one of these before I went Chinese but I'm making my own so it doesn't bother me either way .
As for the welds on the latest pics they do look a lot neater which is appealing to a lot of ppl and even if not scene u have piece of mind u have a relatively good looking setup
That's my 2c
Gl with it
Hybrid , just wondering if you could post some more photos of the collector/where the piping merges? Just looking for some macro shots inside. Many thanks.
Giday mate,
Ill post up some pix soon of the collectors for you guys
thanks
I've just gone thru this NZ based supplier's website and all I can say is wow! the prices are good. He is even selling manifold/ turbo packages and manifold/ wastegate packages.
What I would like to ask is, do you do GT3076R spec turbos as I only saw the GT3540 which is too big for my street application- R34 aiming for a responsive 280-300rwkw. What brand wastegates are those, hoping not some cheap chinese shit, and how reliable are your turbos- i know its NZ assembled, is there any write-up on them? Cheers Ron
Giday mate,
Thanks for the support.
Our 3540 is aimed for larger power as the rear housing is quiet big. We will be doing some smaller sizes in the near future. Turbo's are high quality and we wouldn't sell it if we didn't know that. the cheaper range we do supply is for people who are on a tighter budget most GT series turbo's we do supply are assembled by us
Our wastegates that we do supply ( we don't manufacture ourself ) but under a very high quality control and are made in Taiwan not china like most cheaper gates that boost creep. we check each item before sold and make sure they are up to standard.
I will be posting up Dyno charts soon of the turbo's / wastegate's being used on our customer's cars.
Thanks Hybrid,
I reckon if you supply smaller turbos identical to 3076/3071 spec with manifold n gate packages at the prices you have, a strong base of dyno charts on customer cars AND solid reliability backing over a long period, then you will have a HUGE following, a big customer base in Australia is almost guaranteed, cheap and solid street spec turbos are in demand, not only in the the Nissan stables but other makes as well. Keep the good work coming. Cheers
Ok guys over the weekend i decided to take the sheets off my old car which i haven't touched in years. It use to have a stainless manifold with a T3/T4 turbo. To give you an idea the turbo was a fine hair line between the covers it was pretty much touching. The pictures bellow are a manifold we put together for a client with a 44mm port , and the turbo size is double what the t3/t4 was this is our GT3540 .70 A/R front and a 1.06 A/R rear, which compared to the old one it was .63,
Nope you can go direct through our site which is now on my signature or PM me and we can go from there.
Thanks
ebay the only way to order these?
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
