"steam Pipe" Single Turbo Manifolds On Fleabay....anyone Know Anythging About This Supplier And Their Products?
  • Replies 384
no probs will do. Its going on the dyno next Friday to test some thing else but that will also answer the spiking question. It seems to be holding and no where near as violent but I aint keen on thrashing it on the street to confirm.
  • 2 months later...
Run mine up today with one of these manifolds. 14psi spring in the manifold and dead steady boost control. Run it up to 17psi and no boost creep what so ever. Very happy.
Any pics of the setup on your car mate?
Sean would love that tight bend right before the throttle body :laugh:
You have the AFM in the cooler piping I take it??
Yeah its rather tight, after talking to a few more people about a FFP im really thinking it may be next :(
Yeah afm's just after the intercooler, i was expecting to have hose problems with it blowing off but didnt have one :)
No but I can grab some. Because the power steering line loops up on the 34's makes the intake pipe tight and the waste gate port runs pretty close to the a/c lines. Not problems though. Had to chop up a 14mm spanner to get 2 bolts done up to and trim 2 studs, actually easier to bolt on then my mate's 6 boost.
Just spent 2 days reading this whole thread (hiding at work haha) general concensus seems good for the money. At the end of the day it's stronger than a china manifold, but cheaper than a 6boost. As long as they fit + hold together + hold boost their a winner in my book. I couldn't care less about pretty welds if they do what their supposed to - but that's just me.
Pm sent
I'm going to wait till there's a twin scroll / split pulse one.. I'll be all over that shit like a sale at bunnings
We do Top mounts currently with split pulse,
Without gate? I am planning to mount the gate on the rear housing instead of off the manifold
Hey MSports what size gate did you end up using? I have to change mine to suit a bigger gate cos I'm spiking from 4500 and above witht the durty 30 with about 20psi worth of springs fitted. I used a Turbosmart 40mm gate.
Yeah, its still a tad messy, was in a rush to finish it, Still gotta neaten it all up.
does it clear the A/C lines, heater lines, extra brake lines (ABS)?
also with the gate installed, does it clear the suspension tower ok?
PICS PICS PICS of under car etc... :)
I used a Tial 44mm MVR, no spiking what so ever, flat boost curve the whole time.
I'll grab some pic's soon, been at work all week, i work 12hr shifts so havnt had a chance.
The A/C line's need to be moved towards the strut tower, i just cable tied it away. Heater hoses are clear although i heat wrapped mine and clear's the ABS fine. No clearance problems anywhere.
I had no clearance problems with my R33, but the gate pipe was sitting way too close to the aircon lines, so i cut it and adjusted the angle slightly and it sits better now. That part could do with a slight redesign tho.
the photos aren't that clear on his eBay site.... but is the wastegate port perpendicular to the flow of the outlet?
    • You could probably just go with the genuine Nissan pads, they are not really the expensive, I can't say how they compare to your 350GT pads but at least they will give decent performance. Shims are probably the reason for the squeal.  When I bought my Q50 which runs the same Akebono brakes, the previous owner had some weird pads fitted and it squealed and dusted like crazy, I bought genuine pads and when I put them in, I found all the shims missing.  With the factory pads, the dusting is much better, performance is fine, but it still squeals when cold.  A bit of grease on the back of the pads and mounting points gets rid of it, but it comes back after a while.  I have bought a genuine shim kit that I need to install when I get around to it, hopefully that will fix the squeal.
    • Highlight that row, and a bit of trial and error. Try reducing it by 25% and see if it starts, if not, go the other way. On the newer Kebabtechs that table is in VE which makes it so much easier to calibrate.
    • That's the one I have in my R32. There isn't a bigger battery that will fit an R32.
    • Not sure what you mean haha. That one doesn't fit mine but when I get sick of my one I'll get a standard one. I just gotta find a way to make it fit cause some shit is in the way.
    • https://www.supercheapauto.com.au/p/century-century-ultra-hi-performance-4wd-battery-ns70x-mf/602477.html MF for Muthaf*kka
