Sorry to hear about the prang Joel :mad: You should be able to get all the parts you need to do a full repair, without it costing too much. It may take a little while, but then so do smash repairers.
I always make a habit of getting NCB protection, you just never know.
https://www.sau.com.au/forums/topic/39165-prang/page/2/#findComment-797636
My previous car was a VS 5ltr manual. It had ABS.
When I first jumped in to the Skyline that was one thing I missed.
Any Idea whats involved in slapping a ABS in to my car?
The VS used to have the wheel speed sensors at the just off the IRS diff (looked like a large set of gears that had an optical looking sensor).
So I would assume if the Skylines are similiar I would need to use an ABS diff or just the (whats the word for them? mental blank) The rods that go to the wheels that provide the drive.
Not depressed at all though.
Gives me a good excuse to finally get the left guard/part of the roof fixed from a bodgy previous repair. + a few other things that were bugging me.
https://www.sau.com.au/forums/topic/39165-prang/page/2/#findComment-804465
names Nhan..ive only been at chevron for bout 6 months?
ive heard about u coz i drive a 32 as well. everyones like "oh joel use to drive a black one"
yeh brendan got his 32 bout 3 months? nice black one with an r34 wing
he came down last weekend so we could help him put lower springs on
so have u fixed ur car yet? might as well put on a bodykit while u r at it!
u should come down and visit us sometime! u'll see three 32 coz ma bro drives one as well
https://www.sau.com.au/forums/topic/39165-prang/page/2/#findComment-818006
nar cars not fixed yet..
I'm keeping the stockish look.
I like the look of a stocker R32, big tyres hanging out the back with a stockish looking muffler that has a nice 3.5" s/steel pipe. I'm not big into milo-tin mufflers, atmo bovs, lowering & big body kits etc. :rant:
Is Gary still there? He use to own a really clean VLT.
I'll come down and show him the new motor when its in.
https://www.sau.com.au/forums/topic/39165-prang/page/2/#findComment-818051
    • Pic of Nos, turbo kit and sequential not loading. 404 not found
    • im sure mine stays in gear and wont shift unless i shift it? and for sure it wont go back to Auto mode if its put in manual mode? if i use paddles but its still in D then of course it goes back to auto mode. but yer if its in -+ and i use paddles it will not auto change gears what so ever and i have tried this. it will gear down if at a stop though which is kinda nice but goes back to 1st gear not D. i think it used to be like this with imports aswell i dunno if its really like it anymore like when i got my R33 it had alot of JDM options which local cars didnt have. Now local cars have kinda caught up even the lower models. but yer transfer rates and other things makes it almost on par.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
