Guys,
I have now finished off the R34 GTT with the East Bear Masterpiece Collection GTT to GTR bodykit.
All other work is completed except for the FMIC.
I want to use the return flow type, to retain the "over the engine" style intake.
http://www.kudosmoto...-neo-p-944.html
I am going to use the intercooler linked above.
I'd like to get some feedback from the members who have installed this unit in the past.
Has it bettered your response or not?
My car is running factory intake and airbox with an HKS panel filter.
The turbo has been hi flowed and is running a modest 10 psi, making 335HP at the fly wheel.
My aim is to better the response, and cool the air better, not more power.
Has anyone found that installing one of these units, actually increases lag?
Many thanks.
Jim
Edited by TR33GT-001
https://www.sau.com.au/forums/topic/391651-blitz-return-flow-fmic/
Guys,
Many thanks.
Jim
Hey mate, cant say i noticed a difference with lag or response, it pretty much didnt change, although i'd def recommend one if you do chose to increase your power down the track, especially with a hiflow turbo.
Cooling the air better is how they make more power.
What are you comparing it with? Do you have a fmic now or the standard GTT smic?
I had a Trust smic (bit bigger than the GTT one) on my Stagea making about 220awkw and changed to a Just Jap return flow making 240awkw with a GCG highflowed GTST turbo on about one bar. I didn't notice any increase in lag but then there was a power increase as well.
I have now changed to an HDi Hybrid fmic with a Greddy copy FF plenum on an RB30 so can't notice any increase in lag or response.
If you have the GTT smic now there will be no improvement in lag but it should be easier to make power.
If you have a fmic now I doubt that you will notice any improvements.
It's presently the OEM SMIC.
I'll wait for a few more replies before deciding.
Thanks for your comments so far guys.
(I'm being overly cautious, for good reason. Money!)
Jim
That's a pretty good power figure for the stock smic. :)
I've always said they were underrated. People used to go on about heatsoak but that was only ever a problem for me on the dyno - not on the street or track.
Having said that I think the Blitz return flow is a good unit and you could wind your highflow up a few psi and you will notice a good power gain with no noticeable downside.
You could save a few bucks by getting this one instead (the one I had) http://justjap.com/store/product.php?productid=17355&cat=0&page=1
But if money is really tight you could carry on as you are until you are ready to upgrade.
You will see a slight pressure drop it's way bigger the stock cooler your also adding piping but would be hardly noticeable but thats my 2c it is a deffinent improvement over stock the gains will out weigh the cons
I have the Blitz LM on mine. Didnt notice any decrease in throttle response or any increase in lag with the stock turbo.
Putting 300rwkw through it now with no dramas. Keeps the intake temps very low. And removes temps very quick if it heats up in traffic etc. It will drop 20+ degrees in a matter of seconds. Even just giving the throttle a stab and holding the revs a bit higher at a standstill the temps plummet.
On the track on a warm day the temps range from 25-35'C giving it full beans. On the road it, 18-25'C.
im using a big ARC return flow dont know to much about them but have heard after a car was tuned by trent after 15 runs the intake temps didnt change at all
and have seen a few results make over 300rwkw with no problems
havent looked into the other brands much so cant really comment on them and i cant say if i noticed a difference as my car came from japan with it fitted
but when my car was stock with full 3 inch stainless dump pipe and exhaust,metal intake pipe 9psi i raced my friends r33 with excatly the same mods except the intercooler he was using a just jap one
head to head i was 2, 2.5 car lengths in front
not sure if that was the coolers doin or not
hope this helps
Lol companies always give redicolous power increases that will never happen. A cooler isnt a power increasing mod like rurbo its a mod like fuel pump it removes a restriction and allows you to get more power out of the pther mods like a turbo.
At what power level though? up to around 300kw they will both be the same its only once the jjr starts to reach its limits and be a restriction is when that could happen. For instance if its just a relatively standard car and you put one on you wont expect a power increase of 80hp,
main difference ive seen with the arc coolers compared to the rest is after 15-20 dyno runs the intake temps havent moved and the arc cooler is cold on both sides i know as i have one and tested it
but dont get me wrong im sure all the other return flows will be good just saying if this guy can find one i wouldnt think twice snapping it up i was lucky my car came from japan with it fitted i wouldnt like to pay 2-3k for a return flow cooler hahah
Yeah I agree the ARC and other jap brand coolers are better than the china ones and will keep temps down better if I have to buy one again it will be a jap brand, I was more trying to point out the fact that some people think a intercooler is a instant power mod.
Yep, an intercooler is a supporting mod only, for the intended power level that is targetted. All good guys. I am going with the Blitz unit, as part of the final mods. Thank you all.:thumbsup:
killer cooler the blitz return type.
  • 3 months later...
Good to hear the blitz turnflows are good for up to 300kw? but how would it compare to the cooling pro option from justjap?
I was set on getting a black cooling pro but im just worried that its not going to be up to the job.
I should also mention I'm planing on getting a HG turbo later in the year and i want to make the right choice now so there are no hassles(i.e. struggling to make the most out of it) later on when tuning the thing.
Thoughts on either cooler for 250 ~ 300 kw applications? - as you can see i havn't yet chosen my ideal setup.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
