A few weeks back the old stag was running a bit rough and the engine light came on... I thought I got some bad fuel so I got some fuel treatment and injector cleaner and disconnected the battery for 24 and it came good.
It only seems to be an issue as the motor warms up then after that she runs ok but the engine light remains on.... Could it be the plugs and if so any1 know the replacement number.
Cheers.
https://www.sau.com.au/forums/topic/391653-engine-light-prob/
It is unlikely that the coils are at fault.
AS mentioned above... get the fault code and then you won't have to speculate.
If I was to take a guess it sounds like your Bank1 or Bank2 sensor is on its way out.
Stuart, if you pull the codes from your car as per the instructions found on either of the links below, we can help you with it and it won't cost you anything.
M35 Stagea Info forum
http://www.m35stagea.info/forum/viewtopic.php?f=6&t=11&sid=d6d780c4e99ca60948000875c6272fd8
SAU (in the Stagea DIY's sticky)
http://www.skylinesaustralia.com/forums/topic/261557-ecu-fault-codes-the-easy-way/
Also, any Nissan dealership can pull any/all codes for you via their Consult.
what cam said is true...u can go to a nissan service/dealer but be ready to part with some money...if i remember nissan camberwell charged me $120 for roughly an hour's work of diagnostic & repairing one of the circuits on the passenger side intake valve
the guys at the dealer were amazed on how i knew which codes came with the CEL
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
