People,
Need some help as this noise is driving me insane...
I have a standard clutch done a little bit now...
The problem is that the pressing the pedal previously would reveal a squak only intermittently.
Now it has progressed to quiet a number of times on an outing, both pressing and realeasing the pedal...
I used some silicone lubcricant (ska don't get any funny ideas) on the lever on the side of the gearbox. This stuff is what I used on my motorbike chain and is a VERY good lubricant, yet the problem still persists.
Any help would be appreaciated!!!
Thanks
Neill
https://www.sau.com.au/forums/topic/39166-squeaky-clutch/
i had/have this problem also.. i tried wd40 or similar under the pedal where the cable is and no change. then i accidentaly oversprayed the spring behind the pedal up the top and the squeak stopped straight away!! came back a few weeks ago but i drenched it in wd40 again and i havent heard a mouse since!
see how you go..
https://www.sau.com.au/forums/topic/39166-squeaky-clutch/#findComment-797351
i know what this is, i had the same problem, its the slave cylinder.
look under the car at the cylinder while a friend pushes the clutch, and as the piston moves in and out it will make the squeek noise...
if you want it to go away, replace the cylinder.. although it problably wont amount to much if left unfixed.
https://www.sau.com.au/forums/topic/39166-squeaky-clutch/#findComment-797653
Slave cylinder hey, I will have to check that again cause it has been recently replaced...
Its driving me nuts I will investigate more on Sat when I can get it up on a hoist...and I tried drowning it in WD40 to no avail, also where is this spring...
And definitely the outside of the car, had the girl push the clutch when I had it on ramps...
https://www.sau.com.au/forums/topic/39166-squeaky-clutch/#findComment-797701
hey guys,
My clutch had the squeek 6 mths after fitting, took it back and they got under the car, removed the rubber boot and sprayed some type of lube on the clutch lever pivot point, all sweet now and the clutch actually feels a bit easyer to press in..
cheers
Lenno
Hmmm might try that tomorrow!!!
https://www.sau.com.au/forums/topic/39166-squeaky-clutch/#findComment-798047
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
