For Sale $1500 firm
17x8.5 and 17.5 Volk rims for sale, with Dunlop Formula R tyres.
Perfect for saving your street tyres at the track :D
Full details and photos here: http://www.hgeconsulting.com.au/cheatertyres/
Team Trackday, here's your chance....
well.....they all *used* to be roadworthy lol
The formula rs are still road legal, I always drive to and from the track on them to save stuffing around when I get there. The tyres currently on the rims need to come off tho...
100% incorrect Al. As per the web page, the tyres on the rims are dead. The rims come with Dunlop Formula Rs which are about 80% new, and are worth $1800 on their own.
I can swap the formula rs onto the rims but its going to cost me $80, so for $1580 I could have the formula rs fitted first. I just dont have access to a cheaper deal to get them done than retail....
Sorry, I'm not willing to seperate tyres and rims.
sidewaymambo, the rims don't have the offset marked on them anywhere, but they do fit over the standard gtst calipers. And, I don't have my r33 any more so I can't fit them up and check it out. You can come and check if they fit over ur brakes if you like, the wheels are in abbotsford.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
