Up for sale is my R32 RB26 Power FC and carbon fibre look hand controller.
Looking for $950 delivered
This has a tune loaded on it for 600cc inj and -7's making 296kw 19psi on E85
I can adjust the injectors to suit buyers car.
R32 GTR ECU with NIStune board installed. Has same tune as above but for 98 octane
$500
Profec B spec 2 boost controller $325 delivered
Both are from my personal GTR.
Can also dyno tune if interested
Cheers
Jez
0414879711
https://www.sau.com.au/forums/topic/391731-r32-gtr-power-fc-and-nistune-ecu/
  • 1 month later...
    • Yep that's a superb price and ther is no way you will over capitalise on you investment.  As to the bracket, again just use the passenger side seat  bracket ( obviously reversed ) as a sample to reshape it and in this case, TIG it back together.
    • Thanks for that.... If only I could do something once and be happy with that, like some people do....
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
    • Yeah, having tried all of those methods including BBQ+recipro/hacksaw, I ended up buying a bush press kit under $150 that works well, like this: https://www.ebay.com.au/itm/355967727167?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=sfmmuhxgqhm&sssrc=2047675&ssuid=dJvnaZ11TB-&widget_ver=artemis&media=COPY It basically has a range of pushers and cups with threaded rods between to press out a range of large bushes. The problem with any sawing solution is minimising damage to the subframe side, although it probably needs a quick sand afterwards no matter what solution you try due to damage
    • Hi. Thanks for the answer. I do not have instagram 😄 I too considering turbo the RB20DE NEO 🙂 But i think i upgrade the gearbox first or at least buy new.
