Hi guys, I think it's time to sell my midnight purple gtr but I would like to see what I get offered and what you guys think. So i will give a very brief run down of the car and what it's got. The car is standard in appearance and runs semi slicks on the standard gtr rims, the engine was built about a year ago and was fitted with forged pistons and rods in the process it also had head studs and main studs fitted along side with hks cams and 6 boost extractors with -5 Garrett turbos fitted. To run the power plant a motec m800 was fitted. There isn't a dollar to spend, sump, catch can, surge tank ,clutch etc has all been done . When the car was tuned I only wanted pump 98 and after a workout it produced 400+ kw at the wheels. Thank guys. Let the fun begin!!
Edited by sloppy
https://www.sau.com.au/forums/topic/391733-eoi-gtr-r33-vspec-m-purple/
People look at photos first. once they like the car shown in photos and understand the description of the car, they will then call you about it and talk it in depth. No 1 would ever try to contact you and discuss about a car or even bother to come to you to inspect the car when you aren't bothered to post photos......It is essential in terms of selling a 2nd hand car. Good luck
  • 1 month later...
If I was looking for a 33 gtr I'd just msg him for pictures as he said to do and call him for a chat.
It annoys me that you people can talk shit in someone thread and the mods don't do anything about it.
If you don't want to buy it (as I'm sure you all don't) then please keep it to yourselves.
If your genuinely trying to help the seller PM him telling him his faults and give him some tips.
The same argument can be made for selling the car.
If you are genuinely looking to sell the car, you will spend the extra two minutes and compose an add that has the details needed and some pictures.
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
