Ok, so me and my brother built a rb25 180sx, we got the front facing plenum and the larger throttle body, its been a few months now without driving the car because their are MANY problems with it and i just realised now we got the series 1 TPS sensor because the throttle body only took the s1 TPS, so im just wondering which wires go where, on the s2 engine loom their is yellow/black...red/blue......blue/black and on the TPS sensor their is blue, white and pink? so any guide to that will help, iv'e looked everywhere and cant find anything on s1 tps -> s2 wiring.
another thing is this: i grabbed a multimeter and measured the volts the wiring is putting off
their should be
yellow/black -> 5volt
blue/black -> ground
red/blue -> TPS signal, BUT im reading like 2.5volts from this? with nothing connected, so its like the ECU is SENDING this wire a voltage? wat the boo!
help would definitely move this purposely built drifter into actually drifting, we finished it last year august, havnt even got a chance to run the engine in yet :(
  • 2 years later...
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
    • This one?? In other news: I cannot tell the difference between my red MX5 with the silver grey hard top......... and the Ferrari 599XX EVO, they might as well be twins, well.......apart from the big wang hanging off the back of the Ferrari...🤔🤣, without the wing they are identical
    • Turn it into the pride flag
    • I think you'll find we're confused about what you were trying to do and how you were doing it. I would have thought that block rigidity was something you measured while loading the block in beam or in torsion, and that you would do so before and after grout filling, to see if putting material in there created a "composite" construction with the expected rigidity increase. Notwithstanding that the true function of grout is less about gross rigidity than local (ie preventing bore deflection/splitting and tying the bores to the main bearing locations a little better, etc etc). It is nearly impossible to follow your description of what you've done without closing ones eyes and making "aliens" hand shapes in front of oneself to try to follow the manipulations you've made. It's still unclear to me what you were trying to prove.
