hey everyone . On my phone so ill be short ?
How many ppl have had their balancer come lose/ oil pump break and damage the collar and end of crank.
Work shop has told me my collar and end of crank has been damaged. I have not seen it,, but they say it might be repairable.
I remember reading a few cases of this happening and was wondering how many of them were fatal to the crank?
Ps. Rb oil pumps ruin the fun :( lol
https://www.sau.com.au/forums/topic/391844-another-oil-pump-question-thread/
Oh ok that sounds easy enough. Mechanic didnt say anything about keyway, just that ballancer was moving a little and damaged the crank.
They did say they had to cut the ballancer off and the timing belt drive off, so hopefully they havent damaged it cutting them off.
Heres hoping its just the keyway haha
Common cause for this is the harmonic balancer bolt being incorrectly torqued.
+1, and it is reasonably common.
was your timing belt ever replaced?
BTW while I agree with Sean, have the crank checked for run out before putting it all back together....because another possibility is a bent crank which means your bearings will be rooted shortly.
Totally agree - the torque specs on that bolt are quiet large meaning that you need to lock the crank - and no the clutch won't hold enough torque to do up the bolt.
You can pull the starter motor to lock the crank or do what I do and drill a small hole through the bell housing enough for a pry bar to lockup the flywheel.
Edited by rob82
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
