hey everyone . On my phone so ill be short ?
How many ppl have had their balancer come lose/ oil pump break and damage the collar and end of crank.
Work shop has told me my collar and end of crank has been damaged. I have not seen it,, but they say it might be repairable.
I remember reading a few cases of this happening and was wondering how many of them were fatal to the crank?
Ps. Rb oil pumps ruin the fun :( lol
https://www.sau.com.au/forums/topic/391844-another-oil-pump-question-thread/
Oh ok that sounds easy enough. Mechanic didnt say anything about keyway, just that ballancer was moving a little and damaged the crank.
They did say they had to cut the ballancer off and the timing belt drive off, so hopefully they havent damaged it cutting them off.
Heres hoping its just the keyway haha
Common cause for this is the harmonic balancer bolt being incorrectly torqued.
+1, and it is reasonably common.
was your timing belt ever replaced?
BTW while I agree with Sean, have the crank checked for run out before putting it all back together....because another possibility is a bent crank which means your bearings will be rooted shortly.
Totally agree - the torque specs on that bolt are quiet large meaning that you need to lock the crank - and no the clutch won't hold enough torque to do up the bolt.
You can pull the starter motor to lock the crank or do what I do and drill a small hole through the bell housing enough for a pry bar to lockup the flywheel.
Edited by rob82
    • Just buy a BMW if you want that... You can then choose whatever engine of theirs you want 😛
    • Clear vinyl wrap or clear coat?
    • There really needs to be an ODBII item that can play intake noise through speakers, synchronized with your current RPM and TPS%.
    • Worth most of the $50k alone!
    • So, we now have a straight and clean boot lid inbound and the car goes in for paint, again, on Wednesday, and will be ready on Friday, all ready to get cams and stuff on Monday  And by straight and clean.....I mean a brand new OEM one that cost..... $1300....😪 Sadly there's no clean undamaged used soft top version available, plenty for the power retractable hard top versions though, which is arse and makes Mark have the sads I could have waited longer, until a NC sort top boot lid eventually turned up, but I'm sick of waiting and said fark it and made it rain cash, meh In other naturally aspirated news, one of the guys at work brought in his old Corola which had a 4AGE in it, really nice clean car with lots of mods, including ITB's, man that things induction noise sounds sick with all of the dorts that makes you smile......maybe the NC needs ITB's, yeah, basically for the noise they make, but they're pretty expensive, but, they sound so damn good I may bring this up when I drop the car up on Monday, and by may, I mean I will🤣🤑🤪🤣
