Hi Guys,
just signed up and will post up pics of my car soon. Well I was going to sell my 350GT and no real takers so I said Ill just keep it and do some mods and so far have done the following
Injen CAI
Motordyne 5/16 Spacer
Fujistubo exhaust with exotic speed Y-Pipe
32mm Spacers at the back and 25mm at front
Tien adjustable Coil overs and Shocks (EDFC)
So the other day I noticed fog/moisture in my drivers side head lights after the rain and upto now still has moisture though it has stopped raining. What I wanted to do is completly change my head lights to these eagle eye head lights which are from america.
Question is, has anyone done this and are they a straight fit as some sellers in US are saying the headlights are for Left hand drive cars, which I find quite har to believe, what can be so different?
Cheers,
Jayce
https://www.sau.com.au/forums/topic/391924-aftermarket-headlights/
  • Replies 478
The light pattern is different. the light pattern for a LHD headlight will kick up to the right, which will blind oncomming drivers. RHD headlight have a light pattern that kicks up to the left to light the side of the road.
if , like me, youre not worried about the beam pattern difference between LHD and RHD cars, you just need to check the wiring.
this is a confusing bit...
Non original HID lights wont work on a factory HID car without wiring changes.
some/most v35s had the factory HID changed to halogen type to suit compliance. how this was done could make these eagle lights work... or it might make everything more difficult to work.
just check which bulbs are being used. if your car has H1 and H4, and if the eagle lights have the same, it SHOULD work. if your car currently has D2R and H4 and the eagle lights have different ones, you'll have electrical dramas.
but..... its nothing an auto electrician cant fix for some extra $$
Edited by Deep Dish V35
I have LHD lights, as seen here:
To answer your question, they're really annoying arcing to oncoming traffic and its forced me to point them down fairly far. But so worth it :)
Edited by sheldon2369
Sheldon, those look pretty darn sex.. have you got a shot of them in all its glory at night?
I've been contemplating for a while in getting Aftermarket Vs the 06 OEM headlights..
Do your lights still automatically turn on / off?
Might look at sourcing them from japan to avoid the whole blinding oncoming traffic thing though...
Yoink!
Adding it to my slideshow background on my PC at home. :thumbsup:
If you want some more pretty pictures of my car + other V's check out my website, I'll just link the photoshoot category for you: http://sgv35.com/category/photoshoots/
Whilst on the topic of headlights, I wanna do custom mounts and projectors but a many people have said you need to bake them to pull them apart or something? Have I been fed crap or is this true
So doing it when i get home later..
I think I'll have to buy the pair of headlights from Yahoo japan... $435 sounds like a steal!
+1 for sheldons response regarding the headlights.
I've seen a picture on g35 of someone who tried to do it himself and failed.. it wasn't pretty.
its true - you'd need to melt the glue in an oven and take the cover off.
+1 I was very skeptical about it, but I gave it a shot cause my right side headlight is too far gone oxidised. So in an attempt to clean them I follow the DIY, which does tell you to bake it or use a heat gun and it worked. It should be fine as long as you don't go over 100 degree C and longer than 5-7 mins.
Well I have to get new headlights now, this money should be going towards the HFC... :(
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
