You wont be able to use they factory HID setup on the sedan lights, there is no mount or hole for the factory setup.
There is just a rubber cap over the back of the globes, which is the only access for the wiring.
You will require an after market set of HID for this to be possible.
  • Replies 478
Easy partner!!! I believe once all has paid he then has to go on the yahoo auction thingy and once he has the headlights he then will contact us for the shipping. From there depending on the type of shipping requested you will have them within 5 days. He did mention of some public holidays over ther in japan, maybe thats the hold up?
Although it has been a while!!!!!
With regards to Jesse purchasing the lights he would be going directly to the supplier.
I regards to the HID setup for the sedan lights, you will not be able to reuse the original setup. Go and buy an aftermarket set of H7 HID's, when you get the new headlights, remove the two wires going into the low beam section and cut them. Now solder these two wires to the power input on the aftermarket HID kit.
The series one sedan factory HID setup is in two parts, the ballast under the headlamp and the igniter module inside the headlight (which requires dismantling of the headlight to get to it). The series 2 sedan and all of the coupe's these two components were combined into the one unit under the headlight.
So retain the factory harness ditch the factory ballast with the factory lights, (do the new ones have halogens in them already?) And replace with aftermarket hid's, that's cool I get em cheap as threw work.
The new lights will come with a harness already attatched, when you unplug and remove your original headlight the harness stays with it you wont require anything off it. You will be splicing into the new harness on the new light.
Nice to see that there are 4 units paid for in full with shipping. I was wondering if anyone has anymore pictures of these lights that they could post on here? Excitement will build even more then while looking at what we are getting soon!!!
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
