These lights will be BETTER than you can even imagine :) ... I am thinking about wiring mine up so the halos stay on during the day too! I have a couple of spare T5 led globes I can sell to whoever wants them for their parkers too - I think they cost me about $10.
  • Replies 478
No idea until we get the lights - but I am assuming that the CCFL halos are wired to the stock parkers - surely it is very easy to separate them and connect them to accessories so they come on when the car is on. We will figure it out when we install the lights.
Disappointed that I missed out on the group buy. Does anyone have any idea where I can still get them or anybody else interested in another group buy?
Email Jesse at [email protected] and tell him you missed out on the group buy, but you want a quote on a set through him - it will cost you a bit more, but anything is doable.
Just paid $198 for a single to Sydney. yep let the fun begin. I'll hold off on installing so I can feed off everyone's experiences and tips/traps, hahaha :yes::action-smiley-069:
I'm paid for , not that this will hold anyone up. Hopefully as the word on the street is it is just unplug the old and plug in the new. I do have a 12/05 Coupe so how hard can this be??????
If the coupe' lights are anything like the sedan ones, the halos wont be conected when you get them. Giving you the option to splice into the parkers/led's or setup a different connection for daytime running lights.
Stoked to get these bad boys on. But since my wiring is a mess (past owner or during compliance, didn't know what they were doing), so I will have to get it all rewired. Any help would be appreciated.
Any idea on what you guys are doing with your old lights? Is there just going to be a mass amount of lights appearing on ebay.lol.
Tyler, Nuwan from Bayswater may be able to help. I spoke to him today and he said if bolt on and off, it will cost $140 (he needs to physically look at the new lights first to confirm). However, if we do a group install, will be cheaper. Plus he may be interested in your old lights so it may end up with cash your way instead. Let me know if you guys are keen.
I can install in GC area...
Will need HIDs swapped from old light to current (pretty fidly and stops the bolt and and off from happening as mentioned above)
Globes swapped over but ideally you need new ones as you have lens (D2R) not projector globes (D2S) and will not get full benefit from light output
Front bumper needs to be partically removed also
Can also help if you want indicator to be re wired to blink and not be constantly on - otherwise its just orange (is in usa models anyway)
If you want LEDs or Halos or Both to constantly be on (during day) if they not already set up like this.
Edited by R6n350GT
I did have some problems with one of my headlights so it may be worth buying new globes. Can anyone recommend what I should purchase?
I did i heap of reading and best ones (for most light output) are
Philips D2S 5000k or 6000k 85122WX Ultinon
Philips D2S 85122CM (~4800K)
we should see if we can get a group buy on them ?
Another group buy! Well I would probably be in. Do you have any further information or pricing, links etc?
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
