Series one and two headlights are different for OEM the series one has a flatter bottom while the series two goes down more and flicks up closer to the grill.
Sedan headlights are all the same, its the outer shape that you need to worry about.
Differance between S1 & S2 from what I can see is that they changed the look on the inside slightly and added height adjustment.
  • Replies 478
Quick update: $500 including shipping....still trying to negotiate and bring it down further.....have told the seller that we are ready to wait a bit longer with respect ro change in shipping methods which could bring the cost a bit down...will keep u guys posted.....
Guys have a look at this link and see if this is the right model...My link
Edited by shiva
Finaly cost is $452 through sea shipping which will take 6 - 9 weeks......Please confirm the below list if you guys are still interested.....
Update list:
Chrome housing(Coupe Models)
1. Shiva
2. 81gSKy
3. Heretical
4. Bigdr33gtst (damian)
5. Nightcrawler
6. thinktea:
Black housing(Coupe Models)
1. Jawrgy
2. gkzlah
3. Mick_V35 (Mick)
4. Runner4life
5. Dreadnought
6. Mayo_85
Sedan: Black Housing
1. Howaitonaito, black housing series one sedan.
Edited by shiva
Confirmed for me: Dreadnought - Black housing
The link above looks right Shiva.
If there are any issues with HID Ballast, Series 1 or 2 etc, I'll work through them on the fly. I don't have any particular expertise here but am happy to test.
I'm also happy to work with the Melbourne/SA people to arrange distribution.
have already asked jesse to check the compatibility of these headlights for series 1 and series 2.....once we confirm the 12 pairs, then we can give jesse different address and he will give his NAB account to which we can transfer the money and he will ship the lights in packages of 2 pairs of lights.....as mentioned earlier, it will be by sea so wait time is 6 to 9 weeks.....
Confirmed List:
1. 4evershiva - Chrome housing
2. Dreadnought - black
Hi Shiva,
Thanks for all your work so far. I have series 3 (bi-xenon lights). Can I trouble you to just double check with Jesse that the series 2 coupe lights are compatible with the series 3 coupe lights. Shouldn't be a difference but wouldn't mind a double check.
Thanks,
Keith
Update list:
1. Shiva
2. 81gSKy
3. Heretical
5. Nightcrawler
6. thinktea:
1. Jawrgy
2. gkzlah
3. Mick_V35 (Mick)
4. Runner4life
5. Dreadnought
6. Mayo_85
I'm still in! WOOT! Can't wait to f@#$ off these oxidated headlights! LOL!
Confirmed List:
Chrome housing:
1. 4evershiva
2. 81gSKy y
3.Nightcrawler
Black housing:
1.Dreadnought
Hey Keith have already asked Jesse to check its compatibility from the early model to the latest...so he will inform me if there is any issues......COMMON GUYS, LETS GET THE LIST CONFIRMED AND GET THIS GOING AS JESSE IS NOT READY TO SPEND MORE TIME ON THIS BUY.......
Still in :)
Should we set an expiry date on the group buy confirmation? I'm not trying to pressure people but we could spin this out for months if not careful.
Edited by Dreadnought
    • Grind them off, drill them out. Repair any rust on the other side. Start again from scratch.
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
    • Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
    • You can also remove the veins from the HICAS portion of your existing pump.
    • Trying to swap the rear subframe on my R34 and can't remove the L-shaped stay brackets between the front subframe mounts and the sill/chassis. I'm in the UK so rust is a problem. I've used loads of WD40 and then Tunap 103 for days beforehand. I backed off the bolts forward a bit, backward a bit repeatedly for ages to try and avoid snapping. They have all moved a few full turns. The one I've spent most time on has come loose and I can turn with fingers, and it will pull down and push up 2-3mm. But it won't come out. I can tighten it back up and loosen it off again repeatedly but it still won't come out. I assumed there's a captive nut inside but if that's broken loose then I can't understand why I can always tighten the bolt back up - I'd expect it to just spin both ways. Any ideas what's happening here? I can't visualise what's inside there to cause this.
