What's your favourite R32 GT-R Colour
112 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hey guys.........
I have started a poll asking what's your favourite colour.
Now I' know it's tempting to simply put your colour down if you own a R32 but I really trying to get an idea of what colours are popular and what's not.
Just pick the colour you like the most. Even though I own a Red Pearl Metalic one, I voted for Jet Silver!
Cheers,
Bob.
I thought KL0 spark silver was a GTR R32 standard colour.
Dont think I have seen BL0 so I chose that - sounds nice
KH2 - Gun Grey Metallic
KG1 - Jet Silver Metallic
TH1 - Dark Blue Pearl
AH3 - Read Pearl Metallic
732 - Black Pearl Metallic
326 - Cristal White
KL0 - Spark Silver Metallic
BL0 - Greyish Blue Pearl (special order)
AN0 - Wine Red
326 - Cristal White
AN0 - Wine Red
Hmmmm...... I wonder what's the difference between Spark Silver and Jet Silver?
I think I can answer my own question......
It appears that Spark Silver replaced Jet Silver at some stage around 1992.
I'd like to see them side by side one day.
Bob.
What about the burgundy red? Right set of wheels and they look tuff as nails
Burgandy Red is actually called Red Pearl Metalic - Paint code AH3 which is what my car is.....
Bob.
Mine is BMW Blue Water Metallic - Paint Code 896
Sounds close to BLO - Greyish/Blue
Looks good in person in full sun light but changes colour depending on light.
Goes from Grey to Blue :wacko:
BTW Bob - yours makes me very jelous sir !
Thats because you spend all your spare time getting marks out of your current paint ;)
Really i only detailed my car once in four years the rest of time it went though auto carwash. Always looked good.
But always looked dirty after 2-3 days, Lucky 2 mates work at carwash's.
Awww i need a Black 32 again.....
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
