Given how much i drive my car, its more like every 4-5 months which in k's is less than 1000. Oil and filter
Why??
The car is rarely driven but started often. It probably idles more minutes than it gets driven. I've heard that with excessive idle time, fuel can dillute the oil, so i play it safe by changing it more regularly than some. Its still only around 2-3 changes a year so its not a massive cost.
I should just get my a$$ into gear and do an oil analysis so i know if it is actually diluting - but seems more effort than 2 changes a year :)
A weekly warm up > 15Km run with occasional sprints > decent warm down > tuck her into bed!
That's the way to treat a healthy athlete - of rarity
...eh Bobby?
Lube with something a bit better than KY Jelly??? :)
lol, thats my plan for this year :)
Hasn't worked so far though. I did wash it on Sunday but, so that meant driven out then back in the garage. Does that count ??
Yeah adds to it...
But leaving a car parked for extended amounts of time in some cases is not good.
Just take it out for a good spirited drive on the weekends.
Cars are meant to be driven.
Yeah adds to it...
I change my oil every 5000km on all my cars.
Very true about not driving the car often. The R34 sits in the garage and only taken out on some sunny days, now the suspension is slighlty noisy, streering sometimes groans. Once I use the car for a few days in a row - no squeeks or groans.
Q. When you're checking over a car for yourself or a friend, do many of you...
a) poke your finger under the filler cap to feel for grit and sludge?
b) smell the oil on the dipstick for burnt odour?
c) check the colour for blackness?
d) check for presence of immiscible water present?
e) check the coolant for oil present?
BTW I change oil every 5000Km or 6 months whichever's earlier + before hard driving.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
