5000k for me
i drive my LM every day have had it a year and put 20000k on it. had problems a few months back with oil leaks from dry cam and cam cover seals and front seal failing, taking out the timing belt at the same time because it sat in a garage for so long.
usually every 5000k's.
i have a few cars to look after tho, so sometimes it can be either more or less, i forget if i dont put it in my book
the wrx likes it every 3000k's. heavily modified, and shitty boxer engine...stinks of fuel.
the skyline likes it every 5000k's. engine runs like a dream.
the pulsar could probably go for 20,000k's before it needed an oil change (it doesn't tho..). its an absolute gem of a car. bullet proof!
the rodeo likes it every 5000k's. its a dirty f**k of an engine.
"I never do! I just let it all happen like - C'est la vie - and if there's smoke or a rattle, I just ask Daddy for a new one!"
That's what one blonde g/f said to me...
Needless to say, she only lasted two dates;
#1 for the excites
#2 for the "You know what? I think you deserve someone much better than I ...." speech.
i change everything on all my cars differently!
my r34 gtt was done every 5000kms but hasnt been touched fir over a year now so gonna do a major on it as soon as i have some time as it is for sale atm!!
my jeep is a company car (and i work at jeep) so maintenance is done as per service guidelines say every 12000kms
my bmw 320d is done as per the handbook also every 15000 my memory!!
ive only had my GTR for 5 months so far! i made the dealer in nsw i bought it from do a service before shipping it to me in melb! ive done only 2500kms but im doing a major for it this week with new filters, fluids plugs etc also doing gates timing belt kit, water pump etc!! (60,000 km on clock) i just dont want it to break before rb30 goes in :)
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
