Dent!
GTR_34
 Share
Hey Guys and Girls I was wondering if anyone could help me out.
This afternoon I had parked my car outside a shopping center. I was sitting inside my car waiting for a freind. While I was waiting some drunk old lady in her 40s slammed her door right into the side of my car.. So I get outside to have a look and there is a dent the size of a 50c coin. No paint has come off so is it possible to get this fixed without having to repaint the entire door ?
The car is a brand new Mazda and is insured. I tried to talking to the lady but she ignored me and started peeing right in front of me in a public car park ....So I just left it at that.
I have never been in a accident or in this kind of situation before so I wasn't quite sure what to do.
I really would hate to have the whole door painted because of a tiny dent but on a black car it does stand out a lot :(
I tried to talking to the lady but she ignored me:(
It's hard talking to a peeing drunk!
Police as Mark suggested could have handled her - and she ain't a lady!
Where's your location so that someone here can recommend a Dent Dr > fixes dents at $80-90 each dent; a lot cheaper than paying insurance excess
 Share
    • You need the kit turbo taipan has shown you because that manifold ia designed have side feed injectors
    • @johnnysr22 did you end up installing the little screen thingy and did it work ?>
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
