Hey guys n gals,
I am trying to identify the make and model of these rims as one of them is missing the centre cap....now i know it can be really hard 2 try and
get these once they go missing but i thought at least if i could id the wheels it might help a little?
Thanks in advance.
https://www.sau.com.au/forums/topic/392089-can-anyone-id-these-rims/
Ok thanks guys, but just to avoid confusion, are these rims made by fabulous or are they a knock off of a fabulous rim made by someone else? Just can't seem to see that centre cap logo anywhere on the fabulous site or rims?
Thanks again guys
Maybe try burning them?
yeh thanks im not a huge fan of the rims but i dont exactly have the cash to replace a whole set of rims atm seeing as my family just expanded by 2.
my mate's selling a set on the Honda forum
http://www.ozhonda.c...eels-for-sale!!
try to contact him :)
thanks i checked them out they are similar but not the same, they must be the original of what mine are copies of as an earlier poster mentioned.
looks like i might be out of luck but thanks for everyones help.
Yeah they do except they don't have the removable center caps!
Yeah I know, I was just saying :)
I would have suggested Aaron from Import Monster as he deals mainly with wheels.
But he is in Melbourne / VIC... He is a Trader on SAU, PM him and see if he could help you out.
How did you get on? Might be cheaper to knock out the other three and get a cheap set of 4 of any knid.
no good apparently they dont have stock anymore and the wheel is discontinued.
im not sure if we are talking about the exact same part here, im not talking about just the circular part with the logo on it, im talking about the
bit you take off to access the wheel nuts.
such an annoying thing to have just one missing though.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
