Item Summary: R32 Gtr, Forged, Single Turbo, $22,000 Quick sale!
Item: 1989 R32 GTR
Item Condition : Pretty tidy overall as can be seen by the photos.
Price and Payment Conditions: $22,000
Please note I'm not after any swaps thanks, I already have another car. Just needs to sell.
Info:
Engine:
CP Forged Pistons 86.5mm and rings
HKS 264' in\ex cams
Adjustable cam gears
High flowed ported and polished head
Stainless steel multilayered head gasket
R33 reman crank (larger oil galleries)
Eagle Rods
ARP main studs
ARP enlarged head studs
N1 oil pump
N1 water pump
Tomei oil restrictor
Block crack tested, honed and decked
ACL race bearings
Gates Timing belt and genuine idler and tensioner
Gates radiator hoses
New 90A alternator
Braided enlarged fuel lines
Brand new genuine CAS ($1200)
Custom alloy catch can with twin breathers- -18 Earls fittings and braided line
BMI billet throttle body
Custom rb26 plenum to suit single throttle body – 20mm shortened runners
HKS Metal intake gaskets
New genuine air intake and water temp sensors
Heater hoses, fuel filter, oil filter and oil have just been changed.
Electrics and fuel:
Link G4 ECU
Delphi 1000cc injectors/ new o-rings
Super Direct ignition coils (red)
Walbro GSS343 fuel pump – New larger wiring and relay set-up to ensure no voltage drop
Sard fuel pressure regulator
HKS fuel rail
New injector plugs
Turbo and pipework:
Garrett GT3582R - .82 rear housing
EPR 60mm Wastegate
QuickSpool high-mount Steam pipe manifold – pretty much identical to 6boost
HKS intercooler
HKS pipework (from cold side of intercooler)
4inch dump pipe
3inch cat back to a HKS HiPower cannon
Brakes/Suspension/Driveline:
HKS Hypermax 2 coilovers and springs(excel condition)
CUSCO rear stabiliser
Project D front upper adjustable camber arms
25mm Aluminium spaces and new bushes on front
R34 Brembo Callipers with recent overhaul
New 330mm Rotors and pads front
R34 master cyl with CUSCO brake stopper
EBC 'Green Stuff' pads in the rear
OS Giken Triple plate clutch and fly wheel, rebuilt by NPC as a twin plate to hold 600Hp atw. (rebuilt 15 000km's ago at a cost of $1100)
Brand new genuine Nissan Clutch slave cylinder
New nissan spigot bush
New nissan rear main oil seal
New nissan throwout bearing
NISMO Strong Release Fork Pivot (30% stronger)
Redline Lightweight shockproof g/box oil
Kazz 2way Diff (New 'solid' type) done 10 000km's
Kazz diff oil
new gaskets, pinion seal, axle seals, and bearings
new CV boots
Interior:
Safety 21 5pt Roll cage(Engineered) (Car therefore registered as 2 seater but this can be changed with removal of cage)
Recaro Drivers Seat w/ bride rail (Engineered)
OPM 90mm dish suede steering wheel with momo button and boss kit
Mines 320km speedo
oil temp, water temp, oil pressure, air/fuel ratio gauge on passenger side dash
Autometer mechanical Oil Pressure gauge
Pioneer head unit
Pioneer 6" speakers in rear, standard in front
Old school turbo timer, 30sec increments
Drift button on handbrake
4wd/2wd switch on dash
Exterior:
Ganador mirrors (electric)
N1 headlights
N1 Rear pods
Vertex Sideskirts
N1 front air ducts
8500K Kaixen Hid Kit
White led number plate bulbs
Wheels:
Gmax – 18x9.5 +20 offset
New Rotella 235/40 tyres on the rear, New Mayrun 235/40 on the front
Extra info:
- The car is modplated for the roll cage, 2 seat conversion, brake upgrade, and seats
-Serviced every 3000km's
- 134 xxx on the odometer
-Car has be featured in HPI magazine issues 108.
- Tuned at Aplus Exhaust and Mechanical on the 16/7/2011 by Andrew Glass
- Car is currently making 508hp atrw on 22psi
Pictures: Below
Contact Details: PM on here, or ring my mobile 0439666827
Edited by zachscalais
https://www.sau.com.au/forums/topic/392094-r32-gtr-508hp/
Thanks guys, I'm only selling because I've bought a 4x4 to tow my 4door 32 to QR.
would that be street legal interstate?
You would have to look into laws regarding emissions and height. Both of those things are easy to fix by winding the coilovers up and plumbing in the wastegate.
https://www.sau.com.au/forums/topic/392094-r32-gtr-508hp/#findComment-6240326
That would totally NOT be street legal in NSW , but is that any surprise, really! NSW is the crappiest state for anything 'fun' or that doesnt conform. The cops here would be all over that like a dog in a meat house!
If i was gonna buy that, id register a business name up in QLD, pay the extra for business rego and keep it rego`d there, then bring it interstate :)
https://www.sau.com.au/forums/topic/392094-r32-gtr-508hp/#findComment-6241986
that is total utter CRAP with minor alterations and a emissions tune it could and WOULD be able to be certified in NSW and regod no worries just a small amount of work and knowing that its all street legal..... in saying that this isnt a car i would expect to see crusing and lapping it up for chicks at the local maccas ....... hence getting defected and in the shit i have been through it all and getting it done agian to get my RB26 built certifited. potential buyers yes you can with some work have this certified and road legal
https://www.sau.com.au/forums/topic/392094-r32-gtr-508hp/#findComment-6243658
Guest
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
