Was this in an R31? Looks like a plug from something of that era near the ecu plug has been put on (and the rest removed and potentially fuel pump relay because there are two green relays there usually) and the plug for power that sits near the passenger strut tower is gone.
I wouldn't touch the loom if it was going into an R32.
https://www.sau.com.au/forums/topic/392102-rb20det-loom/#findComment-6240005
A loom is easy to cut wires off and hide them under the tape...If you have taken it for the injector loom and ignighter loom then it's pretty much worthless as you cannot plug it into an R32. As I said the plug for power is missing from what I can tell and I'm 99% sure the plug near the ECU for the body is for an earlier nissan.
https://www.sau.com.au/forums/topic/392102-rb20det-loom/#findComment-6240546
