Hey guys,
Recently carried out the first major service in my series 2 manual stagea (25 neo) with a friend of mine. After starting the car up once everything was put back together we had noticed a misfire whilst revving the car and holding the revs then slowly backing off. The misfire would only occur whilst backing off the throttle and holding it in the one spot. Have temporarily fixed the issue by retarding the timing and adjusting the revs. The more it was advanced the more the misfire would occur and the more obvious it would become ..
I seem to think it may be the cam pulleys that weren't lined up properly but my friend says the car would not start if they were out... Car was running fine with no misfire before the service was carried out and its really upsetting me thinking something major has gone wrong and I'm going to be spending unnecessary money to get it looked at and fixed.
Any ideas and a solution to this problem, may it be the ignition timing/timing not set right or could it be the pulleys weren't lined up properly?
Looking forward to your responses.
Hoping its not that... Would a skipped tooth result in a misfire the way i have described it or could it be the ignition timing which wasn't set correctly because we never marked where it was sitting prior to removing the CAS?
A timing light wasn't used at all during the change to set it to 15 degrees @ 650rpm.
Would the car still be running if it has skipped a tooth because it seems like its running fine now once we've taken timing out of it but i know its not good for the engine.
So your diagnosis would be the timing is too advanced or retarded...?
I kept thinking to myself it couldn't have been anything else besides the timing, I did insist several times throughout the change and persisted to my mate who said not to worry about it, Due to it being a "so called" waste of time.. The timing degrees isn't there for no reason
:rant: Some people irritate me, Is there any possibility the valves have been bent? Car is running almost fine but the CAS isn't lining up to the previous marks before it was taken off and getting a slight rough patch between 1,200-1,800rpm
Still not happy with it because the CAS should be in the previous position from my understanding.
Edited by hks33
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
