Hey guys, just looking for some advice and recommendations on what we should be looking at next in terms of parts to keep the car on the road and in one piece. Just for a bit of background I have a fairly current build thread going in the projects, build ups section Boxheads R32 GT-R Anyways onto what i'm here for, the car is almost ready to be sent for tuning to DVS JEZ but the turbos are capable of producing more power than is a good idea for stock internals supposedly.
The Tomei M8260 kit is said to be 650ps rated and as far as we know, the internals are stock 115k items. Are there ways to identify internally modified car parts through testing? As far as it states in the turbo booklet and from various other sources certain internals will only take around 500ps so it's not the best situation as you might see. We know what the basic idea of parts needed for top but is there any particular setups that will help benefit the car now and in the future? A Link ECU is on order for the thinking side, a few other goodies such as a v-cam setup, forged pistons and rods, camshafts and gears, fuel pump and mostly other parts around the motor in preparation for the engine being opened up. The car is staying on the street but will be a track bias setup hopefully. Cheers for any advice guys n gals.:action-smiley-069:
https://www.sau.com.au/forums/topic/392125-stage-two-mod-advice/
You could simply look @ the rods/pistons and work it out. You'll soon see comparing to stock ones - if they are or not.
Are you really going to persist with those turbo's though? You know the info on them, and you know they are unfortunately... very average.
Also do you realise the cost that v-cam is?
If you did, you'd soon sell the turbos and just buy decent ones. Be better gains for dollar than v-cam will get you. Not saying v-cam is bad, but there is $10,000 more to spend before going that route in all honesty and turbo selection is the single most important thing to spend the money on in the first place. You can have 11ty supporting mods, but if the turbos are rubbish it'll always be an 'average' setup.
Other wise, simply set a power goal and plug into the search essentially (300rwkw, 330rwkw, 400rwkw etc). Info/parts are all covered in more detail than you'll get on one thread.
Yeah, they aren't awe inspiring but they are something different, which i'm interested to see. For now we're using them, but likely they will get replaced when we look for more than 650ps, I'm just trying to get an idea of what would be some thoughtful mods for the limits we have now and for if/when turbos are replaced with higher output items. VCam is expensive and unnecessary currently and these turbos aren't the greatest but I still think a very decent setup could be had from them. It's just going to be something new that hopefully DVS JEZ can work with well. Cheers.
Tomei ARMS M8260
This link has pretty much the same info we got in the booklets.
Edited by K4L4M1TY
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
