Hi allI have just purchased a new greddy td06 20g and i overlooked it had a trust Mitsubishi triangle shaped 3 bolt flange type. It is going on my 20det and I am now looking for a adaptor like the t3 to t25 ones you can get and vice versa but I can not find them on the market anymore. Does anyone know who has them as the turbo is going in next week and need this sorted ASAP..
All help would be much appreciated as I've been looking a few days now...Cheers
https://www.sau.com.au/forums/topic/392174-flange-adaptor/
OR, for $150 just buy the back door Kando the Great housing that will bolt to your modded manifold! :)
Even a well made spacer will just be introducing more bolts and gaskets to leak and decrease clearance to the inner strut upgright
http://www.ebay.com.au/itm/Turbine-Housing-Kinugawa-TD06SL2-20G-T67-25G-T3-8cm-AR61-V-Band-External-/270900070544?pt=AU_Car_Parts_Accessories&hash=item3f12e70890#ht_2093wt_1270
https://www.sau.com.au/forums/topic/392174-flange-adaptor/#findComment-6240665
1329541464[/url]' post='6240665']
http://www.ebay.com....#ht_2093wt_1270
That's what my mate said as well and for 150 its the same price of a custom spacer but didn't wana go that route unless I new I'd have Clarence issues with a adaptor. Has anyone else done this before or is just buying a t3 housing going to be the easiest way. rant.gif
https://www.sau.com.au/forums/topic/392174-flange-adaptor/#findComment-6240751
Buy the kando housing to suit your turbo.
Pull the rear housing off and measure the diameter of the largest point of the wheel (exducer). Then buy the housing to suit which one you have.
61mm = TD06SL2
65mm = Standard TD06
67mm = TD06H
Kando the great has the housings you want for any of the above. Turn your nightmare into a near bolt on affair. Please read the kando thread for further detail.
https://www.sau.com.au/forums/topic/392174-flange-adaptor/#findComment-6241005
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
