up for sale ive got a r33 series 2 front bar in white, genuine plastic includes lights $250
r33 gtr active lsd including pump lines and tank. $800
series 2 r33 abs unit and lines $150
series 2 r33 short block $500.
series 2 r33 engine loom $150
r33 gtr front guards and raises in silver $500.
rb26 twin high mount manifold $200.
r33 gtr front grill in silver with badge $250
r33 veilside side skirts $200
r33 400R front bar still in gel coat $250
os giken twin plate suit rebuild $500
2 r33 dashes $50 each
rb26 carbon fibre timing cover $100.
A set of gtr injectors that have been flowed and tested $250
nismo B pillars $100.
also have 2 aircon systems including condenser, pump and lines $250 each
buyer to organise shipping as i dont have time.
pm me on here or txt me on 0457106174.
Pics up soon.
Edited by skitzs rb26 gtst
  • 4 weeks later...
  • 1 month later...
price drop
r33 gtr active lsd including pump lines and tank. $600
series 2 r33 abs unit and lines $100
series 2 r33 short block $250.
series 2 r33 engine loom $50
r33 gtr front guards and raises in silver $400.
rb26 twin high mount manifold $100.
r33 gtr front grill in silver with badge $150
r33 veilside side skirts $100
r33 400R front bar still in gel coat $150
os giken twin plate suit rebuild $300
nismo B pillars $75.
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
