  • Replies 190
If you have a ignition barrel pm me
pm sent,
do u have aftemarket turbo to cat exhaust?
yes but i need it for another car,
would you sell the gtr end caps alone? and how much for the fuel pump and o2 sensor.
end caps off the spoiler went with the spoiler, if your talking b-pillar trmis they are for sale.
fuel pump i need so not for sale, nor is the o2 sensor.
cheers,
Intrested in all 4 coilovers and intercooler info needed brands size costs condition etc
coilovers not for sale, stock cooler setup sold pending pickup
Hey mate, willing to separate the head ?
hey im keeping motor for another car
hey mate
do you have the plactic part that goes around the gear shift etc? just that one plastic piece?
i have a shifter surround yes but from memory it isn't perfect, may require coat of paint
i would have to check and get back to you
SOLD:
Air Duct Airbox to LHS Guard
PS Pump
Floor Mats
Antenna
Relay/Fuse Box
Standard Struts
A Pillar Trim
Driver Electric Window Switch
Series 2 Front Lip
Instrument Cluster
Diff
Rear Driveshafts
Passanger Door Trim
AC Compressor & Bracket
S3 Xenons
Rear Seats
Front Lower Control Arms
Boot Trims, Plastics, & Carpet
Brake Air Ducts
Driver Seatbelt
Steering Column
Spare Tyre
Relay/Fuse Box Lid
Atessa Pump
GTR Wing (boot lid still available)
Sunvisor Clips
Rear Hubs
BOV's & Return
Intercooler & Piping
i know your thread say minus the exhuast, but does that include only cat back or did the car have a front pipe at all on it? if so what type?
PM cheers
Daz
hey daz, i have stock front pipes lying around that i could sell but i'm using the full afternarket exhaust that was on the car
chris.
SOLD:
PS Pump
Floor Mats
Antenna
Relay/Fuse Box
Standard Struts
A Pillar Trim
Series 2 Front Lip
Instrument Cluster
Diff
Rear Driveshafts
Passanger Door Trim
S3 Xenons
Rear Seats
Brake Air Ducts
Driver Seatbelt
Steering Column
Spare Tyre
Relay/Fuse Box Lid
Atessa Pump
Sunvisor Clips
Rear Hubs
BOV's & Return
Rear Mud Flaps
    • Also, a tip for young players  Check the dates on new tyres before they fit them, I always ask this question at the tyre shop, as they have tried to put "new" tyres on one of my cars a few years ago, but the build date was about 3 years old
    • Yeah - 4 or 5 years is the limit for decent tyres. Pedestrian grade tyres with 400 TW ratings start out hard and don't start to suffer until they are somewhat older again. But the stickier decent stuff? Nup. My current ADO9s are < 2 yrs old, 17000km in, only have about the minimum 2mm of tread depth left, and they are.....not what they used to be. They are clearly much harder now than when new. Whether that is heat cycles (unlikely, for a road tyre), different compound between top and bottom of tread, or actually aging out (in less than 2 years!!!) is not really able to be discerned. But I'd credit actual aging as being at least part of the cause. I've got an old pair of ~50% worn AD08Rs in the shed that I really need to get rid of. They started feeling waaaay too hard to put back on the car after a couple of years sitting there.
    • Personally I wouldn't put tyres over 4 or 5 years old on any of my own cars. Once they go hard the grip characteristics completely change. As per most things it only matters in an accident and that's when you most want them to do their job!
    • I'm replacing the front tyres on the E39 tomorrow because one of them has a few gouges out of it. There is so much tread still on them but they're also 9 years old and the rubber is super hard.  This falls within the guidelines of 10 years old that I've read which surprises me given their condition.  I'm curious about whether you guys care about tyre age or just judge the tyre based on condition? How old would you consider too old?
    • What starts as a scratch, becomes a flesh wound, then quadruple amputation. Jus' sayin'. Crush resistant gloves (The ones with the rubber strips down the back of the hand and fingers) might not be a bad idea after all!
