Hi,
Just wondering if you have the front nose badge and mount and the gtr coin slot cover??
Seems a little silly asking for these, but #$%@head broke in and stole them.
Thanks,
Greebo
  • Replies 190
Hi,
Thanks,
Greebo
Greebo,
Yes i have both, sent you PM.
do u have the brembo from braiks ?? if so how much ?
no brakes, sorry.
Hi mate . After rhf side skirt that bolts to guard . And if you still have front bar if damaged can you send picks ?
yes i have the skirt and damaged front bar. will send you PM
SOLD:
Air Duct Airbox to LHS Guard
PS Pump
Floor Mats
Antenna
Relay/Fuse Box
Standard Struts
A Pillar Trim
Driver Electric Window Switch
Series 2 Front Lip
Instrument Cluster
Diff
Rear Driveshafts
Passanger Door Trim
AC Compressor & Bracket
S3 Xenons
Rear Seats
Front Lower Control Arms
Boot Trims, Plastics, & Carpet
Brake Air Ducts
Driver Seatbelt
Steering Column
Spare Tyre
Relay/Fuse Box Lid
Atessa Pump
GTR Wing (boot lid still available)
Sunvisor Clips
Rear Hubs
BOV's & Return
Intercooler & Piping
Driver Side Front Sideskirt Section
SOLD:
PS Pump
Floor Mats
Antenna
Relay/Fuse Box
Standard Struts
A Pillar Trim
Series 2 Front Lip
Instrument Cluster
Diff
Rear Driveshafts
Passanger Door Trim
S3 Xenons
Rear Seats
Brake Air Ducts
Driver Seatbelt
Steering Column
Spare Tyre
Relay/Fuse Box Lid
Atessa Pump
Sunvisor Clips
Rear Hubs
BOV's & Return
GRT Badge & Mount from Grille (Grille still available)
GTR Coin Slot Cover
SOLD:
PS Pump
Floor Mats
Antenna
Relay/Fuse Box
Standard Struts
Driver A Pillar Trim
Driver lectric Window Switch
Series 2 Front Lip
Instrument Cluster
Diff
Rear Driveshafts
Passanger Door Trim
Series 3 Xenons
Rear Seats
Brake Air Ducts
Driver Seatbelt
Steering Column
Spare Tyre
Relay/Fuse Box Lid
Atessa Pump
Sunvisor Clips
Rear Hubs
BOV's & Return
Driver Front Sideskirt Section
GTR Coin Slot Cover
Rear Subframe
ignitor & driver's side arm-rest insert/window switch plastic surround thingy??
sorry dude can't help you with either..
SOLD:
PS Pump
Floor Mats
Antenna
Relay/Fuse Box
Standard Struts
Series 2 Front Lip
Instrument Cluster
Diff
Rear Driveshafts
Passanger Door Trim
Series 3 Xenons
Rear Seats
Brake Air Ducts
Driver Seatbelt
Steering Column
Spare Tyre
Relay/Fuse Box Lid
Atessa Pump
Sunvisor Clips
Rear Hubs
BOV's & Return
GTR Coin Slot Cover
Rear Subframe
Front Indicators
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
