SOLD:
Air Duct Airbox to LHS Guard
PS Pump
Floor Mats
Antenna
Relay/Fuse Box
Standard Struts
Driver A Pillar Trim
Driver lectric Window Switch
Series 2 Front Lip
Instrument Cluster
Diff
Rear Driveshafts
Passanger Door Trim
AC Compressor & Bracket
Series 3 Xenons
Rear Seats
Front Lower Control Arms
Boot Trims, Plastics, & Carpet
Brake Air Ducts
Driver Seatbelt
Steering Column
Spare Tyre
Relay/Fuse Box Lid
Atessa Pump
GTR Wing (boot lid still available)
Sunvisor Clips
Rear Hubs
BOV's & Return
Intercooler & Piping
Driver Front Sideskirt Section
GRT Badge & Mount from Grille (Grille still available)
GTR Coin Slot Cover
Rear Subframe
Front Indicators
Heater Core
  • Replies 190
SOLD:
PS Pump
Floor Mats
Antenna
Relay/Fuse Box
Standard Struts
Series 2 Front Lip
Instrument Cluster
Diff
Rear Driveshafts
Passanger Door Trim
Series 3 Xenons
Rear Seats
Brake Air Ducts
Driver Seatbelt
Steering Column
Spare Tyre
Relay/Fuse Box Lid
Atessa Pump
Sunvisor Clips
Rear Hubs
BOV's & Return
GTR Coin Slot Cover
Rear Subframe
Front Indicators
Heater Core
Sunvisors
Hey mate. Chasing the ignition barrel trim that lights up along with the triangular trim it all clips in together.
Know what part I mean ?
Still got it ? Pm me
Please
pm sent
can't be bothered reading the 7 pages of posts.
Is the shell for sale?
yes shell is soon up for grabs, sent you pm mate.
SOLD:
PS Pump
Floor Mats
Antenna
Relay/Fuse Box
Standard Struts
Series 2 Front Lip
Instrument Cluster
Diff
Rear Driveshafts
Passanger Door Trim
Series 3 Xenons
Rear Seats
Brake Air Ducts
Driver Seatbelt
Steering Column
Spare Tyre
Relay/Fuse Box Lid
Atessa Pump
Sunvisor Clips
Rear Hubs
BOV's & Return
GTR Coin Slot Cover
Rear Subframe
Front Indicators
Heater Core
Sunvisors
Sideskirts
SOLD:
PS Pump
Floor Mats
Antenna
Relay/Fuse Box
Standard Struts
Series 2 Front Lip
Instrument Cluster
Diff
Rear Driveshafts
Passanger Door Trim
Series 3 Xenons
Rear Seats
Brake Air Ducts
Driver Seatbelt
Steering Column
Spare Tyre
Relay/Fuse Box Lid
Atessa Pump
Sunvisor Clips
Rear Hubs
BOV's & Return
GTR Coin Slot Cover
Rear Subframe
Front Indicators
Heater Core
Sunvisors
Sideskirts
Boot/Fuel Release Cable
Gyro behind Airbag
SOLD:
PS Pump
Floor Mats
Antenna
Relay/Fuse Box
Standard Struts
Series 2 Front Lip
Instrument Cluster
Diff
Rear Driveshafts
Passanger Door Trim
Series 3 Xenons
Rear Seats
Brake Air Ducts
Driver Seatbelt
Steering Column
Spare Tyre
Relay/Fuse Box Lid
Atessa Pump
Sunvisor Clips
Rear Hubs
BOV's & Return
GTR Coin Slot Cover
Rear Subframe
Front Indicators
Heater Core
Sunvisors
Sideskirts
Gyro behind Airbag
Side Mirrors
  • 3 weeks later...
SOLD:
PS Pump
Floor Mats
Antenna
Relay/Fuse Box
Standard Struts
Series 2 Front Lip
Instrument Cluster
Diff
Rear Driveshafts
Passanger Door Trim
Series 3 Xenons
Rear Seats
Brake Air Ducts
Driver Seatbelt
Steering Column
Spare Tyre
Relay/Fuse Box Lid
Atessa Pump
Sunvisor Clips
Rear Hubs
BOV's & Return
GTR Coin Slot Cover
Rear Subframe
Front Indicators
Heater Core
Sunvisors
Sideskirts
Gyro behind Airbag
Side Mirrors
Rear Bar Skin (reo still available)
SOLD:
PS Pump
Floor Mats
Antenna
Relay/Fuse Box
Standard Struts
Series 2 Front Lip
Instrument Cluster
Diff
Rear Driveshafts
Passanger Door Trim
Series 3 Xenons
Rear Seats
Brake Air Ducts
Driver Seatbelt
Steering Column
Spare Tyre
Relay/Fuse Box Lid
Atessa Pump
Sunvisor Clips
Rear Hubs
BOV's & Return
GTR Coin Slot Cover
Rear Subframe
Front Indicators
Heater Core
Sunvisors
Sideskirts
Gyro behind Airbag
Side Mirrors
Rear Sway Bar & Brackets
Boot Lock Assembly
Complete Set of Locks + 2 x GTR KEYS
SOLD:
PS Pump
Floor Mats
Antenna
Relay/Fuse Box
Standard Struts
Series 2 Front Lip
Instrument Cluster
Diff
Rear Driveshafts
Passanger Door Trim
Series 3 Xenons
Rear Seats
Brake Air Ducts
Driver Seatbelt
Steering Column
Spare Tyre
Relay/Fuse Box Lid
Atessa Pump
Sunvisor Clips
Rear Hubs
BOV's & Return
GTR Coin Slot Cover
Rear Subframe
Front Indicators
Heater Core
Sunvisors
Sideskirts
Gyro behind Airbag
Side Mirrors
Boot Lock Assembly
Fuel Cap Flap
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
