hicas
guys,my hicas indicator(yellow light?) is perpetually on when i'm driving. i thought it's only sposed to kick in at certain instances. is there something wrong? if so, does it require urgent fixing?
also, this is out of curiousity. i saw a r33 gtst skyline displaying a p plate getting pulled over recently - are p platers barred from driving cars like the skyline?
the HICAS light is a fault indicator light. If it's on it means there are problems. The most common cause i believe is low power steering fluid.
Check your PS resevoir.
You should get it fixed soon, as the rear wheel alignment might be out slighty due to the hicas not working properly. If thats the case then you could be scrubbing your rear tyres. My hicas light came on during a trip to melbourn, by the time I got there from canberra both my rear tyres (19 , 275's) were f*cked... Ended up costing me $1400 to replace :-{
Go to the FAQ section dude... there is a big write up about HICAS
From what i hear (good ol grapevine) is that Victoria has Power to wight ratio's...
Skylines have more power than what P plater are allowed.... *i think*
Is your car a r32 or r33, r34. If its a r32 then like sewid said, its probably power steering fluid. Otherwise its a electronic problem as the R33 has an electronic hicas system, Ie there are no hydrolics involved.
Pedars seem to know a little about these, do a search on hicas error codes and a like, it might yeld some results...
Sorry I could not be more help, you might just need a wheel alignment or one of the wires may have come loose if you have a r33...
you can always reset your hicas by plugging out the wires from the box and then turning the car on... then turn the car off and plug them back in and turn the car on and see if it helps.
I'm not a mechanic so I don't guarantee success and cannot be blamed if something goes wrong so do it at your own risk. Oh and like the boys said check the power steering fluid and re-fill if needed. Good luck.
wasn't alluding to that. my mechanic is a great guy but when i first said hicas he went : "Harh??" =)
i took a drive earlier today. the weirdest thing is that the hicas light did not come on once. did it just fix itself or should i still get it checked?
that dosnt mean they are are bad mechanic but i'd think about changing to someone who knows a bit more about skylines.
 Share
