Turbos
Air intake
Front pipe
Will suite both R32 and R33 GTR's.
Ecu and hard pipe kit are for 33 GTR only.
Come on peeps. Turbos are dirt cheap for a working set.
Air intake costs less than buying adapters.
Front pipe is sturdy and reliable. Beats having that stock front pipe anyday.
  • 3 weeks later...
Hey mate, you wouldn't happen to be selling any of the exterior parts are you or know anyone who is. I'am looking for a front bumper for a 33 GTS-T, S1.. I saw you live in Kensington, same here man.
Cheers
Rusty
Great news Rusty. But Im not selling anything other than what is listed.
Troll the for sale section.
Also
HKS EVC 3 and ECU sold to Toshi
Items left
Clutch $90
Front Pipe $50
K&N pods and elbows $30
Im keeping the hard pipe kit
Make some offers
Take the clutch and give it to jim berry if you want. Costs you a fraction of the cost and youll have your clutch as a backup while you get one built to spec.
Edited by eat_me
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
