Hi Everybody.
It's a little known fact that the AFM harness/plug assembly from any 6cyl VL Commodore will fit a Z32 afm without modification. Don't get ripped $40 or more for a Tomei item.
Of course you will need to splice it into your Nissan harness, solder, heatshrink & pack the lot with butyl or similar sealant, this is basic stuff. See the pic for pinouts.
https://www.sau.com.au/forums/topic/39227-save-on-installing-z32-afm/
  • 3 weeks later...
  • 3 months later...
note actual ecu/loom pin connections for z31/r31 VG/RB30xxx are different locations and voltages (2-4 volt)
A - mixture
B - VCC (12v ign relay)
C - cleaning
D - output (2-4v)
E - ECU gnd
F - chasis gnd
z32/r32 upwards are 0-5v and ecus are very similar. using the RB30 plug of course as described mentioned above isn't a problem!
Hi Everybody.
Does anyone know if the wire colours on a R32 GTSt correspond with the wire colours in the diagram in the first post?
As per Joels post, the S1 R33 AFM plugged into his R32 GTSt and ran like it was a R32 item, just want to be sure before I start cutting wires!
Chris
Stoop Question.Does that diagram correspond with being able to wire a Z32 in place of S1R33 afm?
Is there a link to show how it is to be done?
Or is there a corresponding wires chart that peeps have had experience with,With positive feedback.
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
