I thought I would share a few photo's of my C210 4 door that I picked up this week. The plan is restore it to original condition. It has had a hit in the front but is in overall good condition. Having said that it will require a full respray and a few interior plastics that have deteriorated sitting in the weather for 3 years between being crashed and when I purchased it last week. Rust wise it's not too bad, with a little bit in a couple of doors and round the back window. I also picked up a C210 Coupe that is only good for parts to repair the front.
1st thing that I will do is repair the damage to the front and then slowly prep for paint.
The aim is to have it completed by September 2013 for the Bay to Birdwood here in South Australia.
This weekend the Mrs and I have spend cleaning up the interior that was very dirty from sitting.
Comments and advice always welcome.
Enjoy:
Picking it up:
After a wash:
Parts car:
Together:
Getting into it:
https://www.sau.com.au/forums/topic/392308-rick31s-c210-4-door/
Looks like a awesome start.
When i red about the hit, I thought it was decent until I scrolled down, should be a easy repair.
whats it like on rust?
Fairly sad 180b SSS in the backround too
Most bits are there for it to come up mint once it's done. Rust wise it's not to bad, just starting to come through in a few areas. Just needs a guard, headlight surround, grill, front bar and the mount for the drivers side bumper mount rewelded as its been torn out of the rail when it was hit.
Very neat Rick.... nice ...your console is okay ..really you just need a centre cover for the cassette player..
and a gear knob ...
get back to you Rick..
...congrats..:cheers:
Cheers
Mario..
Thanks Mario! The console came up ok once I took it out and scrubbed it and removed the pocket that was badly sun damaged. Also the console lid needs some attention, I was thinking of getting it covered with leather. I assume that that is a common problem as the parts car is worse. Badly need a gear knob though.
  • Like 1
motor trimmer can fix the console cover, also i will let you know what i dig up from someone i know who owes me a favour here..for the gear knob
Hi Rick, Looks like you have a spare LH headlight assembly now. And you're after a gear knob. As I'm not concerned with originality, we may be able work something out where I get a LH headlight assembly and you get a gear knob. With a bit of cash your way of course. Let me know if you're interested.
I'm interested, shoot us a PM with what you have in mind.
too bad the coupe is full of rust. such and rare shape :-)
go hard with the resto man. will be so worth it!
It is a shame, but we will be doing a resto on a Coupe next by the looks of it :D . The Mrs likes the shape more than the sedan.
i really like your gear-stick boot. leather knot is a nice touch.
It came up a lot better than I thought it would, it was really dirty but just used hand wash in a bucket of water. I thought it was standard with the knot in it, my Stanza has the same one..
Congrats on the start of a great looking project!
in regards to the 'oh crap' rust pic...
Can you make sure you document what you end up doing as Im looking at e few similar repairs in the future, so many ways to tackle it but no idea what works best!
  • 3 weeks later...
hi rick spotted a orange c210 coupe at the uni when i pick up my son . next time i am over there this week i will check it out & see if it is a auto .
cheers mick
Hey Mick, any luck with the Orange Coupe?
If anyone needs any C210 Coupe parts shoot me a PM. The whole car is in average condition so expect the parts to be as well. Or if the whole car is of use to anyone let me know, I have taken all the front bolt on panels.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
