Hi, my apologies if this has been asked before . . .can a GTR front bumper and bonnet be fitted to a GTT without much hassle?can the GTT reo be used? the catch needs to be changed?
I presume this is for a R34, yes you can put the GT-R bumper and bonnet on a GT-T but you will also need the GT-R front guards as they are wider than the the standard GT-T one's which means you will pretty much need the rear quarter panel guards as well since it will look weird with pumped guards up front and the skinny GT-T rear, and yes the bonnet latch needs to be changed and the hinge's too if I recall.
There's old post's that go into more detail floating round on here if you have a search.
Edited by ecliptor
yeah definatley for a r34 as in the title of my post . . sounds like i wont be doing this as it looks to be a LOT of work and would explain why i havnt seen one on the road, thanks for the replies guys :thumbsup:
Edited by StevenCJR31
I recently just put a bonnet and bumper on my GTT.
The front bumper can fit with the standard GTT guards with a bit of overhang in the guards (about 5mm or so). I suppose you could cut that bit off but I'm not too fussed about the over hang hence why I didn't get the GTR fenders and like ecliptor said it would've look funny with wide front and narrow rear
PM me if you have any questions
  • 6 months later...
quick Q r u able to use the standard reo from the GTT and where did u get ur hinges from and how much as i am in process of doing change over now
  • 5 months later...
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
