Ahhh... The weekly question.
"safe boost" search results
Next time try to use the search.. Searching for safe boost will show you threads that have the word safe and boost in the same posts but in no particular order. Searching for "safe boost" will search for posts in threads that littlerally say SAFE BOOST in that order so you will find the right results.
Thread closed.
https://www.sau.com.au/forums/topic/392344-ceramic-turbos/#findComment-6242423
Hey man stuff that guy. 12 psi is generally whats acceptable, FMIC, exhaust and stuff will probably help it run a little cooler. I have heard of others running a richer tune and running like 16 psi because it runs cooler rich or something.
https://www.sau.com.au/forums/topic/392344-ceramic-turbos/#findComment-6242448
Thread closed. Believe it or not, but since SAU started more than 7 years ago, this topic has been discussed before.
Please use the search function in future. It may be found here:
http://www.skylinesaustralia.com/forums/index.php?app=core&module=search&search_in=forums
While we understand that it can be frustrating to have your thread closed - Please consider that other members may feel it to be disrespectful and selfish of you to post a simple question, without using the search feature to review the wealth of information provided by said members over the years.
If you still feel that this action is unjust, then please PM me and we can discuss it further.
https://www.sau.com.au/forums/topic/392344-ceramic-turbos/#findComment-6242549
