Anyone after a cheap r33? located Brisbane. Looking for $7500 Ono. Just about to put another 6 months rego on it.
1997 r33 (rego shows 1996 Nissan fast shows 1997)
155000 km on chassis
Unknown km on engine stock turbo (racq electronic compression test when I bought it showed 90% or above on all 6 cylinders)
3inch turbo back exhaust
Greddy / data Logit gauges control boxes.
Apexi rsm, auto gauge for boost
Tpiece boost controller (8psi)
Blitz pod filter
After market oil cooler, filter relocated, earls braided lines
Tein type HA coil overs
After market front strut brace
18s with staggered fitment (85% tread left)
USB/iPod alpine headunit, jvc speakers
Keyless entry with immobiliser (installed by Chris R)
New o2 sensor done 5 months ago
New Bendix front brake pads
Gearbox and diff oil done about 8 months ago
Radiator flushed + coolant 3 months ago
New throttle body gasket
Problems:
Front bar needs replacing ( I have a replica 400r front bar and 2 brand new Nissan clear indicators, front bar just needs painting and fitment + install indicators)
Slight knock from the rear suspension, Doesn't effect the handling, have been told its the D bushes that are worn. No leaks either.
Clutch needs adjusting possibly needs a new clutch fork boot. Clutch isn't slipping and still bites quite well.
Air conditioning needs regassing.
Apart from the few minor problems the car has never missed a bit. Doesn't blow smoke, starts first time everytime. The paint is pretty good apart from a few stone chips. Side skirts and rear bar could do with a new coat of paint.
Pm for pics. Make offers.
https://www.sau.com.au/forums/topic/392380-eoi-r33-series-2/
Also it has a blitz bov
new ngk iridium plugs gapped to .8mm
Forgot to mention the driver side window possible needs a new motor. It still works but stops about an inch from the top. A little nudge and it will go all the way up but fails to click itself off. Have been quoted around 150 to fix the window with genuine Nissan parts.
Whilst I know the car is in good condition, the couple of minor problems have been taken into consideration and reflected in the price.
Located west side of Brisbane
Edited by defari
  • 1 month later...
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
