Hi,
I have a Nismo LCD Instrument Cluster with computer that I have been running in my car, but as I never track my car or make use of the track features of the computer. I thought I'd see if anyone was interested in it.
Computer is still in the car, but not hooked up to a video output. Dash has been removed to not clock up kms while its up for sale. Has 100590 kms on the dash.
The LCD Instrument Cluster is plug and play, replaces old dash of R33 GTS-T or GTR, the LCD has a video in plug.
Epson EJ1 System has 5 wires that tap into wires from the ECU loom and can be used with aftermarket ecu. Then plugs in to the dash through the video cable.
There are switches on the computer box, which you set according to which engine is running in the car.
Nismo dashes are rare. I have seen just LCD dash for sale without computer for $1200
http://www.skylinesaustralia.com/forums/topic/326614-nismo-lcd-instrument-cluster-for-r33
I'm after $1250 for this set. Complete Setup is extremely rare. Located in Perth.
Pics show the menu bars, lots of different things can be displayed as well as kms on the clock.
Cheers.
Edited by Skysthelimit
  • 3 weeks later...
  • 3 months later...
  • 2 months later...
sorry stopped coming to this site.
Yes the Nismo cluster and race computer is still available and up for sale
  • 1 year later...
    • R32 HICAS, so long as the CU is not itself faulty, is easy to keep working enough for the PS. Just unplug the smaller of the two loom plugs, on the CU, like I have already said about 4000 times on this forum. This works with all the stock hardware, or with a lock bar, or with a complete removal. I know, because I have done all of them. OK, actually, I never put a lock bar on because why would you put a lock bar on when you can get rid of the whole lot, including the stupid tie rod ends?
    • Join the NorCal facebook group btw, but if you can confirm it is HICAS I would install a lock bar and do the work to keep the HICAS control unit happy despite the hardware not functioning. The HICAS control unit is also responsible for speed sensitive power steering so if it's unhappy you'll get failsafe/heavy power steering. A standalone can control that power steering solenoid valve but sometimes it's just easier to stick with the factory setup. Tomei makes a little electronic module that you can install to fool the control unit. I would probably go through the effort to not use a scotch-lok and build a harness so I don't have to chop up the OEM harness. Where you could source those connectors and pins I wouldn't know at the moment though.
    • Oh, another question comes to mind though. What sort of shitty fuel are you feeding it. Mine, a turbo, has to be fed 98RON, so it doesn't ping itself to death. 98 in Oz is good, dense fuel with minimal oxygenated compounds. Meaning that the energy density is high, and if the O2 trim is working, you will get more MPG than with a lesser fuel. If you're using some sort of piss poor E10 blend with some other MBTE or other oxygenated additions, that could explain using more per mile.
    • I have no idea where the thump is coming from, it sounds like its from behind me but im not exactly sure. And it was the HICAS light that came on.   I think a complete delete is the route im going to go. Probably going to pick up the kit within the next month and get it installed. HICAS is just going to end up being a headache if I keep it.    Thanks you.
    • Just putting this here for reference for other beginners. Similar to what I said above.  I learnt if you have a few dents that are fairly close to each other (within a couple of inches maybe 2-4 inches?) Use filler across them all and sand it all at once with the long block as opposed to fixing them seperately.  Will make life MUCH easier because you won't get stuck in the cycle that I did. I think doing it seperately there is some overlap (mean your whole repair zone might cover near the area of the other dent) and you start sanding near the other dent making a low spot.
