does it have the cover for the master cylinder compartment? Mine never came with one.. i have the one for the battery though.
Let me know.
You need a LHD battery cover. And I think there was some custom work involved, but Cam (iamhe77) can confirm.
  • Replies 162
What happened to the original Stagea that you needed the motor AND wiring?
+1 Don't you have the old engine and loom still? I could be interested in both.
yeah, G35 battery cover and shroud.
Need to cut about 10-15mm off the top of the steel frame so that the cover can sit in position.
Also recommended to make up two small brackets for the holes at the top to clip into and make it secure.
Looks awesome though and will definitely be an early addition to my PNM35.
http://www.skylinesaustralia.com/forums/topic/311501-m35-brake-fluid-panel-cover/page__view__findpost__p__5147723
http://www.skylinesa...ost__p__5147723
as in this ?
http://www.ebay.com.au/itm/New-JDM-Battery-Cover-2003-2007-G35-/230681766789?pt=Motors_Car_Truck_Parts_Accessories&hash=item35b5b46b85
Same thing, except for the other side.
We want their battery cover to complete the look and they want ours....
That's basically what you have on your car. G35 being LHD has their battery and brake fluid areas opposite to us
Interested in the drivers seat.
What is the condition of the leather? any cracks or tears?
Need the plastic card holder under the visor also. Mine has a broken leg.
Do you have the security blind for the boot? Mine is torn.
Thanks
Thanks
Cargo blind is sold, posted late last week and arrived by courier today. thumbsup.gif
Thanks Chad, appreciate the fast sending of the item.
I'll let you know if there's anything else I need.
Cheers mate,
Jas
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
