Hey everyone sadly its time to put my beloved R32 GTR up for sale.Its been a 5 yr love affair with this awesome car but unfortunately the house has to come first
The car is currently unregistered and became the "project" along with alot of other things.
The rear quaters n rear bumper have some clear pealing body is straight.
Car runs but due to mods need an aftermarket ecu and tune.
A few minor mods so far:
Engine:
R33 GTR Crankshaft
Genuine Nissan Bearings(crank)
N1 Oil Pump
2x Garret 2860-5 Turbochargers
Stainless Dump Pipes with Twin Screamer pipes (Non Atmospheric)
Apex'i intakes and pods
3.5" 5zigen exhaust with Xforce cannon
Stainless 2x2.5"-3" Front Pipe
Nismo engine mounts
600x300x100 intercooler
Blitz BOV
Engine damper kit
Custom Fibreglass Airbox
Bosch 044 External Fuel Pump (In Boot)
HKS Style fuel Rail
Polished Custom Surge Tank (In Boot)
Sard Fuel Regulator
Oil Cooler Kit With Oil Filter Relocator
Performance Wise Turbo Piping Kit
Battery Relocated to Boot
GReddy Billet Oil Cap
Blitz Radiator Cap
Custom Oil Catch Can and Over Flow Bottle
Earls Braided fuel n Vacume Lines
Earls and Speed Flow Fittings
Gates Racing Timing Belt (Blue)
N1 Water Pump
R34 GTR Coil Cover Emblem
JJR Coils
NGK Iridium Plugs (Gapped to .8mm)
Ported and Polished Plenum Chamber
Relocated Power Steering Resoviour and Charcole Canister
Drivetrain:
Extreme Brass Button Clutch
Standard GTR gearbox and diffs
Suspension:
BC Racing BR Series Coilovers
Nismo front and rear strut braces
Camber Adjustable Front Upper Control Arms
Camber Adjustable Rear upper Control Arms
B-Pillar Brace
Wheels and Tyres:
19 x 9.5 Axis Deepdish in shadow finish with 245/35 ZR19 Nexan's
Interior:
Nismo 320km/h Cluster
Momo Race EVO Steering Wheel
Momo Boss Kit
Nismo Leather Gear Knob
Blitz BLM Boost Gauge
Apexi Pen Turbo Timer
Detachable Steering Hub
Turbosmart E-Boost
Exterior:
Custom R34 Nismo Front Defuser To suit R32
Tinted Windows
Nismo Bonnet lip
Original GTR Front Bar
Pumped Front Guards
Rolled Rear Guards
TBO Side Skirts
Trust Rear Pods
Top Secret Rear Defuser
8000k Blue H.I.D Kit
I have a custom fuel system ive built for the boot of this car that is not included in the price of sale but is optional for a $2000 extra.
No stereo comes with the car either.
Heres some photos
Car owes me in excess of $60 000
Asking Price $27500ono
Will negotiate on price, please no tyre kicker genuine enquiries only
If your after a gtr that needs minimal money spent to become a monster than this is the car for you.
https://www.sau.com.au/forums/topic/392388-r32-gtr-for-sale/
Not a bad looking car at all.
May be hard to get $27k for it however its still a very impressive car. I like the R34 front diffuser thats been retro fitted, looks very tough indeed :thumbsup:
Amusing how people need to comment on the price and say it to high. I think the price is very fair looking at the images and mods done. Stick with it had a deposit on mine within 3 weeks at over 40k.
A lot of hard work has gone into this car looking at the images, love the front diffuser as fuel set up :thumbsup:
Best of luck with the sale
  • Like 1
thanks mate i appreciate you noticing the detail n effort that ive put in.I was gonna put 30k on it but thought see how i go at $27500
  • 3 weeks later...
  • 9 months later...
    • Google says for a 1998 Nissan Maxima to pull/pry, and the metal pin might even come out with it. I'd do a bit more googling, there was a few videos, find some where the shafts/needles appear most similar and compare the techniques.
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
    • I particularly like the look of the John Player Special team. (Thumbnail isn't different but hit play for the clip)
    • Such a cool collection of cars back then.
    • Mystery solved, thanks bro Bit of a strange mix, but i dont mind it, still looks good.
