Okay about six months ago before I used the wrong fuel and detonated my engine I was making 223rwkws (the engine had just been rebuilt, don’t just 8000ks). Since then the engine has been repaired again replacing two pistons and all the rings. After running it in I changed the oil and headed down to Race Pace with Mobil 8000 in the car. After Ben made the necessary adjustments the car put out just 203rwkws. Ben played around for quite some time and couldn’t get the car to match its previous 223rwkw run. The 20rwkw loss is unexplainable since nothing in the car has really changed.
The performance loss is not really the issue though. For some reason the engine was pinging on the dyno, Ben fixed this but whenever I boot it now the “Check” light goes off flashing. Basically the car is still ever so slightly pinging :mad: Any ideas on why the car might be making less power and why a well turned engine with good fuel oil and so on would be pinging?
https://www.sau.com.au/forums/topic/39240-powerloss-pinging/
well, there are alot of different things that can cause detonation and powerloss.
BOV leaking or leak in one of the intercooler pipes and vacuum lines is the first place I would be looking.
Then you could check the injectors are flowing ok, if you have an adjustable fuel pressure reg, is the pressure the right - its easy for someone to accidentally fark with shit when its sitting on a work bench.
A couple of places that may be worth looking at anyways - alot of stuff can happen to an engine when it is pulled apart.
https://www.sau.com.au/forums/topic/39240-powerloss-pinging/#findComment-797378
Thanx for the time guys, took it to Ben today and he fixed it ... think it was mostly a dodgy knock sensor. Anyway, the car runs better and safer now. Cant really tell you what he did, just used some of that magic of his!
https://www.sau.com.au/forums/topic/39240-powerloss-pinging/#findComment-798350
    • Pic of Nos, turbo kit and sequential not loading. 404 not found
    • im sure mine stays in gear and wont shift unless i shift it? and for sure it wont go back to Auto mode if its put in manual mode? if i use paddles but its still in D then of course it goes back to auto mode. but yer if its in -+ and i use paddles it will not auto change gears what so ever and i have tried this. it will gear down if at a stop though which is kinda nice but goes back to 1st gear not D. i think it used to be like this with imports aswell i dunno if its really like it anymore like when i got my R33 it had alot of JDM options which local cars didnt have. Now local cars have kinda caught up even the lower models. but yer transfer rates and other things makes it almost on par.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
