How is that a design fault when you guys say it's from lack of servicing!!!
It's no different to the oil squirtters for the cams in my SR and the built in tiny oil restrictor in my BB Garrett turbo on it. Service the car correctly and they don't block up, don't service the car and they might. Or I suppose that's a design fault too!
For a problem that appears as widespread as this; yes, I believe it is. The guys are only postulating that poor servicing causes it, which is quite possible. Are we now saying virtually all Japanese owners don't service their cars?
My question is; why would you use a 1mm aperture, when a 2mm aperture works fine and wouldn't block up?
Why is the turbo on our car a 100 000km service item: when on most cars, they can last the life of the vehicle?
If you don't think there's something amiss there; that's fine, but coming from an engineering background, I know that some manufacturers DESIGN some components to fail deliberately; and what better than a 10 cent part that then takes out a $3000 part (oem price) and costs $5000 in labour to repair. On a car that is now worth how much? So 8 grand in parts and labour; because you won't drill a 1mm larger hole in a banjo...
On top of that; surprise surprise; none of this covered by the cars warranty...
Edited by Daleo
How many cars do you know that are released with a turbo tuned to 13ps?
IMO Nissan accepted potential failure of turbo as an acceptable risk to produce a true sports wagon (Grand tourer)
And don't forget the ceramic turbine wheel.
Edited by slippylotion
The thing is; the particular reason it appears to be failing is because of inadequate oil supply through an unnecessarily small oil feed orifice.
Scotty ran a used, stock turbo at 19 PSI for months with no issues; doesn't seem to be the turbo itself that is the issue. Seems to be it's support system that causes the problem.
I'm not saying that you shouldn't have to change the oil, and that the car should run forever; just that one hole could be a tiny bit larger, with no detriment to anything else and it mightn't fail at all.
I don't believe that Nissan accepted any kind of failure as an acceptable risk; if they had, the turbo would be a no cost, warranty replacement item, or you'd introduce an updated, or improved part.
If you're happy for the customer to replace an expensive component using their own money, after only 100,000km; you haven't taken any risk at all.
This particular argument doesn't involve boost pressures, ceramic turbines, SR20det piston cooling jets or any other distraction; it's about a 1 mm hole in a banjo bolt.
Edited by Daleo
I agree Dale but many oem turbo's have this issue. The amount of XR6 GT35's I have heard of that have failed due to the oil feed filter blocking up, as long as its cleaned occasionally there is no issue. The problem with ours is it only takes a little gunge to block it.
I hate it how you always sit on the fence Dale. Why don't you get an opinion for once?
LOL. :)
This is sort of my point Scotty; if it was a little bigger from the factory, it might not be an issue at all.
The only down side to having a larger hole in the banjo; is more oil in the turbo core, and that could be cured with a larger diameter oil drain line to allow the aerated oil to escape.
Which is something that could be incorporated at the design stage. Which brings us back to my original point.
I was going to bring up the XR6 turbo feed filter; and removed it so as not to dilute the argument.
Filters should be changed, and normally have a service schedule, so the Falcon one is more a case of overlooking part of the schedule because people didn't even know it was there.
A better example would be the catalytic converter in the intake of WRX's that collapses and then destroys the turbo and/or engine. That shit is bad design.
I'm not trying to put Paul or anyone else offside; but this seems to have really pissed him off. Mate; if you think Nissan did an excellent job; don't change a thing.thumbsup.gif
I don't happen to think they did; and worse than that; I think they did it on purpose.
If cars don't eventually wear out, and eventually cost more to repair than they are worth; why would anyone buy a new one?
Deliberately restricting the service life of components is something manufacturers have done for many years. I believe this is an excellent example.cheers.gif
I'm going to shut up now; as I've taken this thread miles off topic already.
Edited by Daleo
loving the feedback on both parties, but if it does absolutely no harm, then why not drill it out to 2mm?
I presume 3 would be pushing it after reading Dale's comments about the larger diameter oil drain
Is it a simple DIY thing that can be done?
ie. whilst servicing it, take out the banjo bolt whilst there is no oil in the engine and get a 2mm drill bit, run it through and give it a bit of a clean up before installing it again?
    • What do you mean?  In between the two I shared?  They're the same boost   This will be insane.   A mate has a GTSt with a 9:1 RB30/25 with Tomei 256 cams and a Borg S362SX-E that is already a beast from the basement but has a stock 5 speed and will probably get a ZF8 one day.  After the G35 900 RB26 setup I'd be lying if the topic of "Wtf would a divided G35 be like on this thing?" idea hadn't come up - you'd definitely want a wide boost control range setup with it, as even with the less responsive and potent S361 we're having to ramp boost in from very low levels in the early gears.
    • ZF8 is faster, wider ratio spread, better in every way. I do not dispute this. But I have brain damage and I want the feeling of shifting gears. To me the extra work is fun, but I daily an automatic and in the US like 90+% of cars are automatic so a manual transmission is an "exotic" experience. If I want an automatic I've driven an F80 M3 with DCT more than a few times and it's incredibly capable but it's emotionally vacant to me.
    • Different folks for different folks I guess - for me, the 6MT > ZF8 claim is wild.  If I had a manual Skyline I'd be saving up fix that with a ZF8.  I went for a M135i, has the N55 which resolves a lot of the issues the N54 has, it already has the ZF8, is barely heavier than an R34 GTt, full boost before 2000rpm while also being real-word-faster than my old 280kw @ hubs R33 GTS25t and doing absolutely everything better.  There's nothing I'd change on it to be more like my old Skyline, tbh... it doesn't sound the same but it's got it's own awesome sound - definitely not worse.   To be fair I can't argue with most of those points.  I guess i was pointing it out as a comparison for a Skyline GTR and it's much closer all around there, like the weight difference between an M240i and an R34 GT-R isn't that much etc.   As above, I ended up getting an M135i which is in the 1400kg range - the M140 and M240is that you can get up till 2018 are B58, ZF8, RWD and in the 1400kg range which is a bit of fun... but doesn't fit the tyre etc of the Supra.  They are a run drive, though- maybe no an A90 Supra but a huge upgrade over a Skyline "sporty chassis" wise.
    • Im loving this thread. I have a g35/900 t4 split 1.00 ar going on my rb30/25 with 9:1 and 264 cams. its drive by wire and with vct i think it should spool nicely. I have the 8speed gearbox on the floor ready to go on so full boost changes will be a thing if the tyres can deal with it. it should always be on boost
    • The trouble for me is the automatic takes away so much from it. And the E92 has hydraulic power steering. Even after putting in an LSD you're looking at re-mapping the xDrive to be more like a Skyline which is just a lot of effort for something that is supposed to be easier and cheaper. I consider the E92 335i 6MT to basically be the obviously superior car to something like an R34 GTT. Half the price out here, the N54 makes so much more power so easily, is a far more refined car, etc. You do have to deal with the nightmare of the N54's foibles vs the B58 which is comparatively miles better and if a turbo does fail it's only one of them vs two and a lot less pipe spaghetti.  996 or 997 Turbo has the AWD system mapped like a Skyline. Basically always RWD unless engaging the front axle makes sense. A coworker let me drive his 997.2 Turbo 6MT and it's absolutely tremendous. I don't think I'd want more power in a street car.
