Hey guys, wrecking my white 97 r33 s2 gtst m spec
Standard Parts-
LSD diff- $150
Brake Calipers-$300 for fronts and rears
Rotors-$300 for fronts and rears
Standard r34 gt rims with road worthy tyres-$300 for the set
Standard r33 gtst rims with shit tyres-$200 for the set
Rear bar-$100
Boot with standard s2 spoiler-$150
Doors with glass and all door linings ect-$100 each
Door trims-$60 each
Mirrors with glass-$60 each
Tail lights-$70 each
Mspec side skirts and rear pods-$160
Apexi 3inch turbo back exhaust- $650
Custom made intake pipe with drift pody- $70
Bosch 040 fuel pump - $100
Standard side mount cooler-$50
Custom leather gtst gear boot, hand brake bag, nismo gear knob-$80
Washer bottles-$15 each
Seat belts-$50 for the alot
Head lights-$300 for both
Suspension-$200 for front and rears
Drivers guard-$70
Interior Dash-$70
Glove box-$30
Rear seat-$80
Rear side interior-$60
Boot interior-$60
SSR PROS chrome 17/9 fronts +16and 17/10 rears +36 with 95% tread all -$2000
Standard jack and jack tools/ bracket-$50
Side window pillars-$30
Skyline floor trims-$40
Bonnet stand-$15
Gteck drift button-$10
Abs unit-$100
Thats all i can think of for now so just ask for other parts with a pm or text.
All pics on demand by mms.
Located in Hallam, Victoria! Contact me by text on 0433467819
https://www.sau.com.au/forums/topic/392439-wrecking-my-r33-s2-gtst-mspec/
I have the cluster but rpm spinny thing is buggered and just spazes out. it could be the wiring in my car or just the lil needle so only want $60 for it. Anfd calipers are sold.
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
