Hey all, I used my high boost today for the first time in a while, Usually I run 15 psi as my high setting but I felt like opening her up a little so I ran 23 psi. I came into 3rd then boosted all the way through the gear, nothing out of the ordinary.
Heres the problem, Car got up to 1.5 bar, then once hit it, it dropped down to 1 bar or so then back up to 1.5 and so on repetitively. So its not very stable to say the least. But when I run 1 bar as max boost like usual its always 100% stable.
I am using the Blitz SBC ID controller and im pretty confident its hooked up right. (Solenoid tapped into the hose that goes to the black cannister by headlight)
The controller is reading directly from the plenum.
Could it be possible the standard R32 GTST bov cant hold that sort of pressure and is leaking? Or should the solenoid have its own direct connection? I can understand it being unstable with a couple psi but a whole 7 psi fluxuating is pretty crazy
Any ideas anyone?
Cheers all
https://www.sau.com.au/forums/topic/392455-not-holding-high-boost-any-ideas/
What turbo? What ecu? i'm going to say either the bov is not holding (blank it off and see), you have a boost leak, your ebc is hitting the limiter and cutting off boost. Does it flop the moment you hit more boost? Why the hell are you using a line from the carbon canister?
Tee into your hot pipe.
I had a similar problem.
I boosted from 10psi to 15psi and it would reach 15 then as i progressed thru revs is dropped down to 10 again.
It was my wastegate lol
Garrett turbo, apexi fc ecu, has been tuned on the boost by previous owner. I don't remember it doing this in the past tho I don't usually hold boost through out gears as long.
It's hooked up that way because that's how the mechanic did it and how it was when I brought the car.
Shouldn't be any back pressure, it was tuned on setup and it iis a Garrett gt2871
Yea pretty much just flopped once it got to the boost setting.
Where's this hot pipe? Everything's running from the plenum :/
Edited by HYBR3D
Well played around with the controller this morning and it's now sitting at 1.45 bar stable as. Think the warning needed changing. You guys are right tho it is a little high for the small thing but nuthing it can't handle :)
You'll be eating those words when the super heated air caused by running the turbo beyond its efficiency range causes the engine to detonate and blows the ring lands off most of your pistons.
Should be fine it has a massive blitz intercooler, and the engine is all forged with all supporting mods.
See what happens I think it will be fine. Either way it's going for another tune shortley. Thanks for the help everyone.
Edited by HYBR3D
That's not how it works hey.
You'll find if you bring the turbo back to an amount of boost where it is at its best efficiency, it will lose very little horsepower, and might even gain some.
Also, a "big" inter-cooler certainly does not counteract the effects of the turbo super heating the air due to inefficiency.
You really need to read up on how they actually work.
There are a lot of people out there that think boost is actually good.... Boost is bad.. Flow is good..
Yea your completley right I won't argue with that. The thing is I don't want to upgrade anything in this setup and I want to achieve the most out I what I have.
The only reason I'm using 1.5 bar is because that's what it's been dynod to already so I'm assuming it's as efficient as it can be there. I'm only re tuning because I have upgrade fuel pump as it was the only thng letting it down last time.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
