Hey all, I used my high boost today for the first time in a while, Usually I run 15 psi as my high setting but I felt like opening her up a little so I ran 23 psi. I came into 3rd then boosted all the way through the gear, nothing out of the ordinary.
Heres the problem, Car got up to 1.5 bar, then once hit it, it dropped down to 1 bar or so then back up to 1.5 and so on repetitively. So its not very stable to say the least. But when I run 1 bar as max boost like usual its always 100% stable.
I am using the Blitz SBC ID controller and im pretty confident its hooked up right. (Solenoid tapped into the hose that goes to the black cannister by headlight)
The controller is reading directly from the plenum.
Could it be possible the standard R32 GTST bov cant hold that sort of pressure and is leaking? Or should the solenoid have its own direct connection? I can understand it being unstable with a couple psi but a whole 7 psi fluxuating is pretty crazy
Any ideas anyone?
Cheers all
https://www.sau.com.au/forums/topic/392455-not-holding-high-boost-any-ideas/
What turbo? What ecu? i'm going to say either the bov is not holding (blank it off and see), you have a boost leak, your ebc is hitting the limiter and cutting off boost. Does it flop the moment you hit more boost? Why the hell are you using a line from the carbon canister?
Tee into your hot pipe.
I had a similar problem.
I boosted from 10psi to 15psi and it would reach 15 then as i progressed thru revs is dropped down to 10 again.
It was my wastegate lol
Garrett turbo, apexi fc ecu, has been tuned on the boost by previous owner. I don't remember it doing this in the past tho I don't usually hold boost through out gears as long.
It's hooked up that way because that's how the mechanic did it and how it was when I brought the car.
Shouldn't be any back pressure, it was tuned on setup and it iis a Garrett gt2871
Yea pretty much just flopped once it got to the boost setting.
Where's this hot pipe? Everything's running from the plenum :/
Edited by HYBR3D
Well played around with the controller this morning and it's now sitting at 1.45 bar stable as. Think the warning needed changing. You guys are right tho it is a little high for the small thing but nuthing it can't handle :)
You'll be eating those words when the super heated air caused by running the turbo beyond its efficiency range causes the engine to detonate and blows the ring lands off most of your pistons.
Should be fine it has a massive blitz intercooler, and the engine is all forged with all supporting mods.
See what happens I think it will be fine. Either way it's going for another tune shortley. Thanks for the help everyone.
Edited by HYBR3D
That's not how it works hey.
You'll find if you bring the turbo back to an amount of boost where it is at its best efficiency, it will lose very little horsepower, and might even gain some.
Also, a "big" inter-cooler certainly does not counteract the effects of the turbo super heating the air due to inefficiency.
You really need to read up on how they actually work.
There are a lot of people out there that think boost is actually good.... Boost is bad.. Flow is good..
Yea your completley right I won't argue with that. The thing is I don't want to upgrade anything in this setup and I want to achieve the most out I what I have.
The only reason I'm using 1.5 bar is because that's what it's been dynod to already so I'm assuming it's as efficient as it can be there. I'm only re tuning because I have upgrade fuel pump as it was the only thng letting it down last time.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
