Just quick question when someone like me (new to the turbo scene)
Buys a stock gts-t what would be the best way to get more power out of it for around 10K like I know the standard stuff but what is a nice lil unit turbo wise that seems to have a all round quality to it?
other than that it's inter cooler bigger injectors and after market ecu that will give you the gain yeah? And is it worth just getting the internals of the stock turbo upgraded to ball bearing?
Thanks for your time guys hopefully one day I can actually join in a turbo debate and know wtf is being said :mad: lol
ignorence is not bliss lol :rofl:
Cheers.
https://www.sau.com.au/forums/topic/39254-has-this-question-already-been-asked/
i would say with 10k
I/C (possible gtr cooler or hybird)
ECU (wolf3d, powerfc, depending on power lvl u might be able to get a chip ecu or a safcII)
Rebuild would be also a good idea again depending on how high you want to go (r33 with sotck internals made 411rwhp)
HKS GT25 - i would say would be a good turbo not 2 laggy and should give you somewhere around 300+ if u want 400 to 500 then you will be a gt30
mike hope this helps :mad:
cheers mike that's what I thought yeah I was just hoping for something average so had the power when I wanted to play. so around the 220/250rwkw maybe?
But that advice is great thanks
Thanks squizz well for 10K if I gave you the car and you brought back a weapon the hell take it lol but wait till I get the money lol oh and the car lmao 2 months :mad: Just doing my home work for now :rofl:
2 npz arian :mad:
If i was in your shoes i would do rebuild, Forget piston,cam, cam gears, strenght rods. Then ecu and gtr cooler (gtr coolers r good for alest 600hp), and if there was money left over a hks gt20 or some sort of turbo rate at about 400hp
Best thing you can do is forget all the advice you just got except the bit about reading the stickies they are where you do your research. The stock R33 turbo is ball bearing. Before you start building it's best to know what you are building on,
ps oh!... and especially don't give your car and $10K to Squizz........give it to me............or maybe just the $10K :wassup:
1. panel filter with cold air induction ~$200
2. Custom m.s 3" turbo back exhaust ~$1100 fitted
3. Hybrid FMIC with piping ~$1200 fitted
4. Bosch 500hp Pump ~$400
5. Injectors ~$750
6. Electronic Boost Controller - AVCR ~$600
7. New ECU PowerFC with hand controller, Tuned ~$2000
8. New Turbo ~$2500
9. Suspension Mods - King Springs with Bilstein shocks - ~$1500
10. Brake Upgrade - DBA Slotted rotors with good pads ~$1200
That goes a bit over the $10 000 budget to around $11 500. Probably allow for about $12 000 to have an all round, reliable, quick street car. I think 220-230kw atw is achievable.
Depends if you want to do some mods yourself too. Tuning will cost a abit depending on what order you do the mods in or if you do them all at once :headspin:
Guest INASNT
pointless getting boost controller and power fc, might as well get a wolf3d with built in boost controll
No once again u have given wrong info.
Power fc and boost controller is fair superior to a wolf 3d.
Also u wouldnt waste time building a strong engine with forged internals then chucking on a pissy 400hp turbo.
ARIAN
For $15,000 u can get 300rwkw without having everything maxed out like stock fuel injectors etc.
nice I was only after 220-250 rwkw for a everyday driver that has the poke to get up and dance on the weekend. But 300rwkw is a nice round number.
Cheers to all so far this is good info I know the sticky threads cover most this but I just wanted a quick simple list of engine mods with out sorting through all the non importaint stuff :(
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
