post-73956-0-28105800-1329820890_thumb.jpgpost-73956-0-28105800-1329820890_thumb.jpgGTR TOP RATED PARTS FOR SALE
All these parts are less than 2000km old near brand new perfect condition
Features:
Garett T04Z rear housing 0.84 T4 divided, rear housing has been ceramic coated = $1,400.00
6 Boost manafold for RB26 this has also been ceramic coated = $1,200.00
Turbo Smart 45m external waste gate = $450.00
3inch custom made dump pipe = $450.00
Air filter custom pipe off the turbo = $150.00
Tomie poncams type - b lift 9.15(these are r34 rb26 gtr cams since i have a r34 nur n1 engine in my r32 gtr)
= $550.00
I ALSO HAVE ALL TURBO AND OIL BRAIDED LINES (ASK FOR PRICES)
ALL THESE PARTS ARE NEAR BRAND NEW THE REASON TO SELL THESE PARTS ARE BECAUSE I AM GOING FOR BIGGER POWER. MY R32 GTR MADE 417KW AT THE WHEELS. NOW AIMING FOR 600KW
*parts are still on the car once items are sold i will take them off.
BRAND NEW PARTS
Features
2x Bosch Z32 airflow metres for RB26 still in the box = $500.00
NUR N1 RB26 oil pump, still in the box = $300.00
NUR N1 Sump and front diff for 34GTR,(bought a NUR N1 R34, RB26 crate motor) there is no need for me to keep as it as i have an R32 GTR = $600.00post-73956-0-28105800-1329820890_thumb.jpgpost-73956-0-48133600-1329820914_thumb.jpg
https://www.sau.com.au/forums/topic/392563-to4z-set-up-for-rb26/
n1 oil pump brand new
bosch z32 airflow meters rb26 brand new
tomie pocams type-b rb26 r34
airfilter and pipe of the turbo
make some offers parts need to go
    • Hi, We've all posted some thread, or know of some other person's thread, that contains information that we want to send people who are asking question to. But if we don't have a link readily available, have to go do a search for the thread before being able to do so. So, it occurred to me that we could possibly utilise the auto-text-replace function that fixes some of my swear words to perhaps auto replace some special keywords with text that also has a link to the thread. A specific example. The thread that I did with the improved R32 GTR wiring diagram scans. If the phrase "R32 GTR wiring diagram" could be auto replaced with "R32 GTR wiring diagram" then all I (or @Duncan, or any of the others that refer to the thread) need to do is remember that that's the keyword (or phrase in this case). OK, it would be better if this keyphrase wasn't that long, but it does need to be specific enough that it doesn't get triggered automatically. And obviously there are threads on turbo topics, or suspension topics that we could treat similarly. Alternatively (and/or additionally), I've been thinking about trying to build a library of the real expert content that is trapped in the bowels of the 25odd years of this site. Things like some of SydneyKid's content. There are threads that he started that should be more easily found, and he has individual posts, or series of posts, in other people's threads, containing very good information. Some of us know that it is there, but....just have no memory of exactly where/when/how we saw it. If we had some sort of library thread, we could put posts in there containing links to things we've found, suggestions for how to categorise it, then a mod or other appointed thread maintainer can copy the link and any key text up into the first post in the library thread. There are probably many other ways to get it done. Some sort of wiki is probably the best way.   Thoughts?
    • But, probably that happened to the last person too, which is why the RTV was there.....if you aren't putting a new gasket in you will need to seal the old gasket back to the metal surface with something, the gaskets will generally only work properly for a single use as they set/harden in that shape
    • What is with the horrible blue and white bit in the centre of the wheels, didn't that come off with some scrubbing?
    • Not sure how broadly you define Northside  but Castle Hill Exhaust are still around and could sort it.
    • I haven't done this as I still use the factory cluster, but I do know the circuits for the flash vs on for hi beam are separate which is likely the issue. The ON runs full power through the switch and the flash uses the relay in the engine bay. I'd hit the wiring diagram per GTSBoy's suggestion
